Hey guys. Tech question! ....Will the XE Stock Radio bezel yr. 2004 fit a 2005 Titan SE. I am looking to replace the radio and want to use a stock Nissan bezel instead of futzing with the Scoshe crap. I have the 6cd changer (non rockford "foster", come on I am not that dumb to waste that money)
Also where do I get the insert for the XE bezel to allow the input of a Double or Single DIN Radio. Thanks in advance.
If using a double din, use the bracket off the factory radio. If single din you will need a kit of somekind to fill in the other half. The 04 should fit an 05.
__________________ Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
I am searching for a Pioneer 9300 9400 930mp or 940mp. SO single din would be the way. I have read about some fit issues with the Metra kit. Where would I buy just the insert without the crappie scoshe or metra bezel?
Some have had problems with the Metra kit, I for one had no problems and think that it is a good bracket. The stock XE bezel is the one I purchased and it is definetly the way to go if going with a aftermarket system. I am in the process of custom painting mine on I would have pics posted of my install.
I had problems with the kit, but it can also be used to mount similar to the Scoshe style using hte HU's trim instead of hte meta trim. It looks much better using the Metra Trim because it allows teh HU to be flush. My HU would not open when mounted this way so I have used the metra kit to install it Scoche way, which uses the trim piece that comes with the HU. It is far from flush though as the HU's trim piece has to sit way back in the Metra kit for my CD-Player. I little modification to the Trim piece that comes witht he Metra and I am going to take it apart again and switch back to the first method, I jsu tneed to grind downthe trim pice about 1/8th on an inch on both sides to avoid my Faceplate arm from tapping it when the HU's face is lowered. It wills till look MUCH bette than the Scosche method. If you do a search for Best Place to Purchase Metra kit my post should some up. The total for everything shipped was about $75 if I remember correctly.
