Go Back   Nissan Titan Forums > Titan Discussion > Titan Visual & Audio Discussion
User Name
Password
Steering Wheel PAC Help - being discussed at Nissan Titan Forums in the Titan Visual & Audio Discussion section.
Old 08-13-2005, 10:24 AM   #1
patcad
Anyone have the color codes for the steering wheel controller wires? i am trying to install my PAC SWIX and either I have the wrong wires or it's not working.
Thanks!
Go Gators!
patcad is offline   Reply With Quote
Old 08-13-2005, 12:03 PM   #2
Sammy Sandbag
Sammy Sandbag's Avatar
This may or may not be correct, since it's been a while since I did this, but this is coming from the AV section of the repair manual.
The plug should be number M98, and it's 12 pins across the top and 12 across the bottom.
You are concerned with pin 13, 12, and 14.
Pin 13 is a solid Green wire
Pin 12 is a solid Red wire
Pin 14 is a solid Blue wire
Here are the PAC SWI-X instructions for the Titan: http://www.pac-audio.com/swixprogram...ehicles&ID=300
-Counsel Yourself
Old 08-13-2005, 02:53 PM   #3
patcad
Awesome Thanks man!
Old 08-13-2005, 08:38 PM   #4
Justintoxicated
Justintoxicated's Avatar
Sounds right to me, TO make things easier, I soldered the white wire to the 2 resistors, and soldered a 2 wires, one to ech Resistor lead, Used some heatshrink to seal it all up, this was I was no soldering the resistors right to the plug shown above.
Old 08-13-2005, 10:00 PM   #5
Sammy Sandbag
Yeah, that's what I did as well. I just used the crimp-on style wire taps to install it onto the truck's harness.
Old 08-14-2005, 05:44 PM   #6
patcad
So did you all tap into the stereo adapter in dash? i'm still having probelms with finding the right wires. My harness's do not resemble whats show above. So i went into the Roof panel and ohm'd out wires 12 13 and 14 to the front. Anyboy have any pics?
Old 08-14-2005, 06:14 PM   #7
Sammy Sandbag
It's the wire harness that your stock bezel plugs to. Easiest way to find it is to just take the wires running from the bezel and follow them down to another harness, that's where you'll find the plug you're looking for. Let me know if you have any more trouble.
Old 08-19-2005, 04:33 PM   #8
smkngtp99
i have ran into the same problems with the programming i am not a dumba$$. the vehicle wiring is different from what you are saying i have no freaking idea what they are and the instructions are not right with the pin numbers. please if anybody knows anything about this vehicle please let me know.
smkngtp99 is offline   Reply With Quote
Old 08-19-2005, 04:35 PM   #9
Justintoxicated
Plug is shown fromt eh Plug in side, not the wire side.
Old 08-19-2005, 04:35 PM   #10
Justintoxicated
instructions worked for me, just find the connector with the same number of pins as in the diagram.
Old 08-19-2005, 04:36 PM   #11
smkngtp99
i found the correct harness with the same number of pins in it but they are totally different. does the rockford system have anything to do with it
Old 08-19-2005, 04:37 PM   #12
Justintoxicated
Originally Posted by smkngtp99
i found the corrent harness with the same number of pins in it but they are totally different
Different than what?
Old 08-19-2005, 04:41 PM   #13
smkngtp99
[quote=Justintoxicated]Different than what?[/QUOTe
oh yeah sorry about that. the pins are missing in the number 14 in the car and several of the other pins it calls for in the instructions
Old 08-19-2005, 04:43 PM   #14
Sammy Sandbag
If you followed the wire from the bezel down to the first plug then followed that wire down to the next plug you should be at the right plug. The PAC instructions should work, that's what everyone has been following. There shouldn't be a difference in the RF or midline in that regards. Ill see if I can dig up anything from the manual.
Old 08-19-2005, 04:44 PM   #15
Sammy Sandbag
can you post a picture?
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
