Old 08-17-2005, 12:58 AM   #1 (permalink)
FM Tuner
hi all
i just bought my Titan two days ago
it came with RF sterio, i am having a problem with the FM tuner that only changes in "odd" numbers only ex. 101.1, 101.3, 101.5 etc.(US system) not 101.1, 101.2, 101.3 etc
i live outside the US and i need to tune in all the FM range i just want to ask if there is anything that i can buy or do to fix this problem
any input is apreciated
thanks
2005 KC 4x4 offroad
Alkhowaiter is offline   Reply With Quote
Old 08-17-2005, 05:32 PM   #2 (permalink)
EVEN FM frequencies??? Where on earth are you???
Nestor is offline   Reply With Quote
Old 08-18-2005, 01:56 AM   #3 (permalink)
hi
i am curently in Saudi Arabia and most of the radio channels here are even numbers.... to be honest, many contries use both odd and even numbers.
Old 08-18-2005, 06:12 AM   #4 (permalink)
You'll need a HU with "European" options.
I gather you imported the Titan from the U.S.?
Old 08-18-2005, 09:31 AM   #5 (permalink)
do you mean to change the whole tuner panel ?
yes i just imported my titan from the US
thanks
Old 08-18-2005, 09:38 AM   #6 (permalink)
The OEM tuner was probably never designed for European FM standards. You will need to replace the head unit with an aftermarket one. You can order adapter kits which include a double-DIN bezel that will accomdate a single or double DIN head unit. The XE version of the Titan uses the same bezel. It's been said the OEM XE bezel is better fitting than an aftermarket one.
Another route is to get a separate tuner of some sort and connect it to the Aux input jack on the dash.
Good luck!
Old 08-18-2005, 09:50 AM   #7 (permalink)
Send a message via ICQ to PuvMan Send a message via AIM to PuvMan Send a message via MSN to PuvMan Send a message via Yahoo to PuvMan
I believe the armada is availabe in the middle east. Perhaps you can get the tuner from there, and swap it.
Born on: 4/11/2005
Signed: 5/21/2005
Delivery: 5/23/2005
05 LE Crew Cab 4X4 SMOKE
Off Road, Big Tow, Navi, DVD, XM, Sunroof, Underseat Storage, Bed Divider, Bed Extender
Aftermarket:
Husky Liners, ActiveTuning Grounding Kit, JetTech Spring Helpers (currently removed), Undercover Tonneau, Lund Interceptor, Wade Window Visors, Fram Boost, Bushwacker Fender Flares, CompuStar 2W900FM-AS, 2* Timing Advance, Siemens HKW-700 Bluetooth Car Kit, Two 11.Kv.2s running of an eD NINe.1 in custom BWR boxes coated with bedliner, 4" PRG Perf Package (SAWs, PRG Arms, 1" Deaver Pack, Bilsteins), 20" Axis Titan rims w/ 33" Nitto Terra Grapplers
Coming Soon:
another new rear end.. haha
trutrac
trac bars
power steps
custom 12" fiberglass sub-box (thanks rcantu!)
Exhaust
PuvMan is offline   Reply With Quote
Old 08-18-2005, 10:30 AM   #8 (permalink)
Wholly smoke, it must have cost a fortune to bring a Titan into Saudi Arabia!!! Would it be cheaper to get XM or Sirious satelitte FM there?
'04 LE, CC, 4x4, Galaxy Black
BT, OR (no locker!!!)
Kennesaw Bumper with Ramsey REP9000 winch and receiver hitch
Advance Cover (aluminum folding cover)
kvoman is offline   Reply With Quote
Old 08-20-2005, 12:31 AM   #9 (permalink)
Thanks Nestor & PuvMan i will follow you valuable advice
& yes kvoman i payed around 30% extra on the titan price to have it imported to saudi arabia.I heard from the dealer that they are consedering importing Titans in the next 2-3 years (i am not waiting that long) specially that the Armada is booming here
but i tell you, it is the best 4x4 car that i ever drove (i had nissan Patrol, Toyota VXR and GMC seira).
thanks & regards
Old 08-23-2005, 11:34 AM   #10 (permalink)
i was about to ask this question as well
im taking my titan home to new zealand in a few months, we use odd and even frequencies as well
SafT is offline   Reply With Quote
Old 08-23-2005, 11:36 AM   #11 (permalink)
oh, our AM uses a 9khz gap instead of 10 too
(1080 ... 1089 ... 1098 etc)
