Go Back   Nissan Titan Forums > Titan Discussion > Titan Visual & Audio Discussion
User Name
Password
Reverse wire harness- Orange/black wire? - being discussed at Nissan Titan Forums in the Titan Visual & Audio Discussion section.
Old 09-14-2005, 10:10 AM   #1
BIGT56PA
Guys, those of you who have used the reverse harness for keeping the stock unit.
The Orange/black wire. it says its the Illumination ground? The other wiring harness does not have this wire. its just on the reverse harness, can I attach this to the radio ground also? The regular harness does not have the orange/black, just the orange for illumination.
Thanks Chris.
04 sedona red SE. JWT intake, full mod stereo with 10" blaupunkt sub. Flowmaster exhaust, undercover plastic bed cover, Westin bullbar, hella lights.
BIGT56PA is offline   Reply With Quote
Old 09-14-2005, 10:17 AM   #2
bestatchess
I did not use that wire. I believe illumination ground is used in situations where it is grounded through a variable resistor to control a dimmer. I was concerned that grounding that wire would create a short to ground and blow a fuse or something.
Old 09-14-2005, 10:25 AM   #3
Sammy Sandbag
Sammy Sandbag's Avatar
Yep, no need for it.
-Counsel Yourself
Old 09-14-2005, 12:53 PM   #4
BIGT56PA
thanks guys a bunch. now I can install this bad boy back in.
chris
Old 09-14-2005, 01:45 PM   #5
rod_b
rod_b's Avatar
Where did you get the reverse harness? I'm thinking about hooking up the RF system in my garage.
8.04 K11 CC LE 4X OR BT PRG'd
rod_b is offline   Reply With Quote
Old 09-14-2005, 01:50 PM   #6
Sammy Sandbag
This what you need to look for: http://www.scosche.com/scosche_carau...&ItemID=NN03RB
Old 09-14-2005, 03:51 PM   #7
rod_b
rod_b's Avatar
Thanks Sammy
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
