I would suggest either having a quality shop do it, or do it yourself. A cheap shop will probably not make an adapter.
The front and rears both need an adapter that must be built (usually out of wood). Do you have access to a jig saw? If you do they are very easy to make. All you have to do is trace the factory speakers onto a piece of wood, then cut it out, then cut a hole for your new speaker.
Crutchfield *may* have speaker adapters premade, but I doubt it. At any rate I suggest a 6 1/2" Speaker in both front and rear, you may get more bass out of a 6x9, but the sound quality goes downhill with those.
Do you currently have the rockford system? Are you planning on powering of the deck? What is your budget?
