if your clipping your pulling way more than 600 watts from the amp, coudl be over 1000 watts and it could also damage your speakers and amplifier...
Also what class is the amp? A/B amps are alot less efficient although they do produce a cleaner more acurate signal (despite wether or no some people can tell the difference) Testing has been done with inconclusive results (once thought to be conclusive in that people can't tell the difference)..
Big 3 will help in that it lowers some resistance in the wiring. Higher resistance means more energy wased as heat rather than geting to your amplifier, headlights etc... Might not make a huge difference though... However if you can gain a couple amps that would be enough to make your headlights not dim...
Caps are not made to prevent yoru headlights for dimming, they are only made to make an already good electrical system better. Reason being they only store charge for a split second, so they don't help as mcuh for long deep bass notes, plus they have to re-fill once emptied which only puts more strain on your alternator, although it might help with dimming it's actualy making the problem worse for your alternator if it is struggling. The big 3 is a better place to start IMO, but don't expect miracles doing it to the titan the length (sort) and size (not tooooo small) of the stock wire ont he titan is not so bad that it should not be able to support 600 watts...
Also if your going to upgrade to a larger alternator then you will need to do the big 3 anyways..
