Old 10-17-2005, 07:58 AM   #1 (permalink)
Aftermarket DVD
Need some help. Well, that too!!
I have a 2005 cc se titan with the non RF radio. I do have the controls for the back seat with the selectors and headphone jacks. Does anyone know what the best aftermarket dvd is that will hook up and work thru the dvd selector on the radio, and will fit in the drop down screen holder.
Thanks
aircum is offline   Reply With Quote
Old 10-17-2005, 08:08 AM   #2 (permalink)
baseballfanz's Avatar
If you want it to fit in the factory drop down, Myron & Davis make a 7 in. and a 9 in.
http://myronanddavis.com/pdut.asp?cateid=12
I use a Blaupunkt ME3 built in tv tuner and can play a wide variety of format, it is hooked up to the factory harness so it plays thru the stereo system w/ out FM modulator. You cannot however control the dvd player itself with the factory HU.
The best price I've seen for the M&D system is here.
http://clubarmada.com/showthread.php?t=2188
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 10-18-2005, 07:51 PM   #3 (permalink)
Thanks for taking your time to include the threads!!
Old 10-20-2005, 03:25 AM   #4 (permalink)
hey baseballfanz,
you said you dvd players is hooked up throught the stock harness, did you do the install you self? how is the sound on the dvd and do you play it through the aux? do you have any pics of your set up? thanx
BulletProof Titan is offline   Reply With Quote
Old 10-20-2005, 06:05 AM   #5 (permalink)
Originally Posted by BulletProof Titan
hey baseballfanz,
Yes it's hook up to the factory harness, let me select "DVD" from the steering wheel controller. Very easy to do. Here's a how to by member "llajumpvid". Just goto Radio Shack and get some RCA cable with one end already strip out.
Old 12-21-2005, 09:06 AM   #6 (permalink)
jedi7001's Avatar
Re: Aftermarket DVD
Baseballfanz: I am assuming this allows you to use the controls in the rear console too, correct? I am looking to doa CarPC with a rear monitor like yours. I want the back seat controls to be functional as well.
jedi7001 is offline   Reply With Quote
Old 12-22-2005, 08:03 AM   #7 (permalink)
Re: Aftermarket DVD
Yes the rear controller still work.
