Old 11-14-2005, 08:43 AM   #1 (permalink)
just need some suggestions
I just hooked up my system in my CC it sounds great. I have a 12" JL audio w3-v2 d4 being pushed by a JL 500/1. My only thing is that now my lights dim but I don't think that my rpms are dropping. Do you guys think that a 1 farad cap would do the trick for my lights? A new altenator isn't really in my price range right now so the cheapest solutions would be the best ones
jree is offline   Reply With Quote
Old 11-14-2005, 08:57 AM   #2 (permalink)
Re: just need some suggestions
If you have not done so already, upgrading the battery/chassis/block ground wire to 0 gage might help.
Old 11-14-2005, 10:52 AM   #3 (permalink)
I just did a search on this upgrade. Do I have to run 0 gauge to do this and is it necessary to do the altenator? Thanks for your help btw
Old 11-14-2005, 10:52 AM   #4 (permalink)
I agree, this is the best solution to your problem right now...
Suspension Mods:
BFG MT/KO 35"x12.5"r17
Audio Mods:
Cooming soon:
HIDs and Yellow Fogs...
Old 11-14-2005, 11:20 AM   #5 (permalink)
I ran 0 gage from the battery to the chassis to the block (per lizard king's post) and did the www.activetuning.com ground wire kit which has an additional wire for the alternator which attaches in addition to the factory ground wire to the alternator.
http://www.activetuning.com/products...04GRNDKT-TNAR/
Installation instructions:
http://www.activetuning.com/products...stallation.php
Old 11-14-2005, 01:36 PM   #6 (permalink)
Banned
TitanFan59's Avatar
A switch to Yellow Top Optima could be in order as well should it only improve marginally.
TitanFan59 is offline   Reply With Quote
Old 11-14-2005, 07:32 PM   #7 (permalink)
Thanks for all the help guys. I was plannin on gettting new battery but now I think that I am going to do the grounding kit as well. When I did my search, a couple people said that they were running a higher wattage system with no dimming and suggested that the ground for the amp might not be that good. Guess it couldn't hurt to try
Old 11-15-2005, 07:57 AM   #8 (permalink)
You should not need to replace the battery at this early stage of it's life. The system should be powered by the alternator not the battery anyway.
Any charging system unless there is a major problem with it should be compatible with a 500/1.
Your problem is most-likely the amp is driven into high levels of clipping. Clipping dramatically increases the average power over time produce by the amp. Increases in average power means an increase in average current. A 500/1 driven into severe clipping can produce average power like a 1000/1. Set the amplifier sensitivity as outlined in Appendix B of the owners manual for starters. If you're using the EQ and it's boosted by 6dB or more, consider more woofers. It's better to get "loud" with dispalcement over excessive "gain" and/or EQ.
If your charging system can't keep up with the system as it is now, adding a capacitor or a new battery will not change that. All power to move a speaker comes from the alternator, the amp simply converts it's output to something useful to do the work.
JLTD is offline   Reply With Quote
Old 11-15-2005, 08:16 PM   #9 (permalink)
Ditto!
Nestor is offline   Reply With Quote
Old 11-15-2005, 11:11 PM   #10 (permalink)
smoketitan's Avatar
lol you guys havent done a search yet on the trusty titan charging system yet have you
Ill check back in a few months to see how long your stock battery last with ANY sort of aftermarket stereo
I dont care if its 400w or 1000w lol, the titan alternator is beyond subpar
but youll see
Old 11-16-2005, 06:04 PM   #11 (permalink)
Blue_Water_Rush's Avatar
but youll see
Does he know something we don't? I'm goin' searchin' (as if I haven't stopped already)lol
A bad day of surf is still better than a good day at work
'05 LE Deep Water Blue/ 4x4/ Off Road/ Big Tow/ Spray In Liner/ Utilitrac
COSMETIC: Undercover Lid/SS Door Accents & Fuel Door/Chrome Tailgate Trim/Dunder Web Grill/Silverstar Headlamps/Volant LED Tail Lights/LED 3rd Brake Light/LED all Int & Ext Lights/ LED Multicolor Interior Accent Lighting/Silblade Wipers/Painted Engine Cover
ENGINE: K&N 77 CAI/Banks Exhaust/AT Grounding Kit/TB Coolant Shutoff/Eco 2 Fuel Vapor Enhancer/Uprev Osiris Tuner & Cipher Software
A/V: Kenwood XXV-01D/JL Audio Amps & 10W7 Sub/MB Quart Spkrs./Sirius Tuner/KK Wiring/SSA Full Sound Deadening/Kuda PDA Base/Laptop GPS with Ram Mount/Tablet DVD with Ram Mount
SUSPENSION: 6" PC Lift/Radflo Coils/3" Deavers/1" Blocks/Bilsteins/PRG Traction Bars/Helo Wheels/PC X Terrain 35x12.50
Blue_Water_Rush is offline   Reply With Quote
Old 11-16-2005, 11:06 PM   #12 (permalink)
Can I get a pic on where the plug in the firewall that the amp power wire can pass through? I read somewhere that its behind the brake booster
Old 11-16-2005, 11:27 PM   #13 (permalink)
pi3yeargrad's Avatar
just drill a hole on the passenger side...REAL QUICK...then buy one of those wire bungs or seal with silicon
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 11-17-2005, 06:40 AM   #14 (permalink)
Here's the spot. The hole is located just above where the hood release cable passes through. Remove the plug, then you will need to push a coat hanger or stiff wire through the hole first because its too hard to reach around the brake booster to reach the wire. Push enough of the hanger through so you can reach it from the engine bay, then drill out the center of the plug to the diameter of the power wire, feed the wire through the plug allowing enough slack on the engine side to reach the battery, then tape the end of the wire to the coat hanger. From the engine side, pull all the slack through til the plug bottoms out against the hole. Re-insert the plug, then run the wire along the chosen course in the engine bay (you can push or pull the wire through the plug accordingly to get the right length to the battery, allow a little extra for mounting the fuse link). Then you can run the wire inside the cab to the amp.
just-need-some-suggestions-firewall-hole.jpg  just-need-some-suggestions-firewall-hole-2.jpg
Need pedal suggestions Kronos1965 Titan Interior Discussion 3 04-14-2006 08:26 AM
Radio suggestions kongmen Titan Visual & Audio Discussion 17 08-14-2005 10:29 PM
Maybe some suggestions? avroflyer Titan Wheels, Tires & Brakes 1 04-01-2005 12:53 PM
