Go Back   Nissan Titan Forums > Titan Discussion > Titan Visual & Audio Discussion
User Name
Password
Sirius install/connect options - through DVD connections? - being discussed at Nissan Titan Forums in the Titan Visual & Audio Discussion section.
Old 12-06-2005, 09:22 AM   #1
DjKamper
I have the starmate replay. Using RF for now - but want to connect for cleaner sound. Tried the AUX and the output from the line out is too low without additional p.i.e or other booster. Also, would like it to be clean and not use the AUX which I am running my ipod through.
Could the dvd connections on the back be used? Is it a standard L/R rca connect? (and does it have a line level input adjust?) Or - something with a proprietary connect like the n-bus for the factory satelite?
Would be great to have a clean install option that works better for this unit than the front AUX... Thanks in advance!
08 LE Desert Stone with Tow
DjKamper is offline   Reply With Quote
Old 12-06-2005, 09:29 AM   #2
Sammy Sandbag
Sammy Sandbag's Avatar
Re: Sirius install/connect options - through DVD connections?
According to the SM, there are no standard connectors for the DVD. Just wired up like the rest of the speakers are (RH, LH, +/-.)
-Counsel Yourself
Old 12-06-2005, 10:04 AM   #3
eakes
There is a PAC adapter which uses the satellite radio connector on the Fosgate and mid-line radios to provide two auxillary inputs. It sells for approx $100.
Old 12-09-2005, 01:12 PM   #4
A2titan
A2titan's Avatar
Found this, will this work?
http://www.autotoys.com/x/catalog/IN...INI_p_946.html
05 Smoke SE CC Big Tow 4X4, Mods: PRG 2" front-PRG 1.5" rear,PRG rear Bilsteins, Banks Exhaust, Front Air Dam, Power Tailgate lock, Fram Air Hog, Prodigy brake controller, Extang Trifecta bed cover. Bed Fade TSB performed by Rhino!
A2titan is offline   Reply With Quote
Old 12-09-2005, 02:38 PM   #5
rrumaner
rrumaner's Avatar
Send a message via ICQ to rrumaner Send a message via AIM to rrumaner Send a message via MSN to rrumaner Send a message via Yahoo to rrumaner
How much clearer do you think it will get? I cannot notice any difference in the sound from the radio vs. the signal coming from the Starmate Replay.
Roy Rumaner
Any questions about the site etc. Lets us know!
rrumaner is offline   Reply With Quote
Old 12-09-2005, 04:23 PM   #6
HokieTitan
other options?
Does the SkyFi or Sportster have the same problem as the Starmate?
HokieTitan is offline   Reply With Quote
Old 01-18-2006, 09:31 AM   #7
baseballfanz
baseballfanz's Avatar
You can convert the line to RCA connector. If your Starmate have RCA outs than you can simply plug into the DVD wire.
Here's a how to by "llajumpvid" to make an RCA input for the factory harness.
http://www.clubarmada.com/showthread.php?t=196
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
User Name
Password
Sirius install jkiller5150 Titan Parts & Accessories 23 09-20-2005 07:05 AM
Sirius Install From The Dealer MPNX2 Titan Interior Discussion 2 04-08-2005 01:03 PM
Sirius install Chris M. Titan Interior Discussion 2 02-22-2005 02:32 PM
Sirius Install Question Jeostang Titan Interior Discussion 3 12-26-2004 11:37 AM
My Sirius Install raxton Titan Interior Discussion 27 12-06-2004 05:33 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
