Old 12-24-2005, 02:27 PM   #1 (permalink)
ecbmxer's Avatar
Strange DMM Readings
OK, so I got a fuse for my multimeter and took some readings to set gains. I set my gains for the subs (500W subs wired to 2 ohms) to around 33V or so with a 50Hz 0Db test tone. and then I went to set my comps. I unplugged one of the speakers and played my 1kHz 0Db test tone and the voltage was only 7V or so. I maxed out the gains and it went up to 12V maximum. I needed it to be around 18V or so. This is for the advertised 85W typical, if I wanted it for the 100W speaker handling power, it would be 20V. Even the lowest RMS rating for the amp is 50W, which would mean 14.14V. Could the impedence of wiring and everything create lower voltages? Now for the second thing. I measured the impedence of my subs just for the heck of it. I have 2 DVC subs that are dual 4 ohm. I have the voice coils wired in series to create 4 ohms per sub, and the subs wired in paralell to create a 2 ohm total load. Now when I measured the total sub output, it was 4 ohms! I went to the terminals for each sub on the side of my box and measured them and they said 5 ohms each. Is this just due to the terminals and wire also? I understand how to wire things in parallel and series so I really don't think its my wiring. I'm really confused here, and it doesn't seem like I'm getting maximum performance out of my system.
2005 Titan SE 4x4
Floor Mats
Splash Guards
Nissan Drop-in Bedliner
Front windows tinted to 35%
In-Channel Vent Visors
Front Husky Liners
STEREO:
Pioneer DEH-P8MP Head Unit
ecbmxer
ecbmxer is offline   Reply With Quote
Old 12-24-2005, 03:08 PM   #2 (permalink)
f00dstamps's Avatar
Send a message via AIM to f00dstamps Send a message via MSN to f00dstamps
Re: Strange DMM Readings
if you have dual voice coils that are 4 ohms, they may be 4 ohms EACH. in series, they would be 8 ohms. parallel that with the other sub and that will be a 4 ohm load across both subs total.
i don't know much about speakers but that's how i think you are getting the 4 ohm number.
i don't know how nice your amp is but if it is 1 ohm stable, parallel the dual voice coils and parallel the subs together. POWER!
2005 CC Titan 4x4 Blizzard White *** SE Popular Package w/ Captain's *** Utility Bed Package w/ Bed Extender *** Offroad Package *** Big Tow Package *** Valentine 1 (hardwired) *** Clifford Matrix RSX 3.5 Alarm + Remote Start *** Amsoil Synthetic motor & gear oil *** 20% Sun-Guard *** Weathertech front floor liners *** Truxedo Lo Pro *** Husky rear floor liner *** HID 4300k Denso/Koito/Philips *** Vulite LED taillights *** Luminarc yellow foglight bulbs *** Scangauge II *** overhead racks w/ kayak attachment *** DR coilovers *** DR rear 4x4 shocks
WANTING TO SELL: bed extender adapter for tonneau covers (i.e. Truxedo)
f00dstamps is offline   Reply With Quote
Old 12-24-2005, 03:28 PM   #3 (permalink)
Speaker Ohm values are impedance, not pure resistance because the coil is an inductor. You can't measure impedance with a DMM. This is probably why you are getting strange readings. There are many cheap impedance meters on the market that you could use for this.
http://www.soundsgoodllc.com
SoundsGood is offline   Reply With Quote
Old 12-24-2005, 05:19 PM   #4 (permalink)
ecbmxer's Avatar
OK, thats what I thought. I figured that the DMM only read resistance rather than impedence. Haha, I was questioning my ability to wire my subs in series and paralell. And they are dual 2 ohm coils, as in 2 ohms per coil. So I could have an 8 ohm, 2 ohm, or 1/2 ohm total impedence. I am using 2 ohm. My amp is only stable down to 1.33 ohms (or three 4 ohm subs wired in paralell) so I can't use anything below that. Well, still gotta figure out the component voltage thing now.
Strange Noise smiley Titan Problems & Dealer Service 4 10-07-2005 11:40 AM
Strange video ... 4x4creature Off-Topic Discussion 4 07-11-2005 09:31 PM
Interesting Readings jmacougar Titan General Discussion 5 01-03-2005 02:45 PM
something very strange titanguy1 Titan Problems & Dealer Service 6 03-10-2004 07:17 PM
Strange Problem Sabre66 Titan General Discussion 3 02-16-2004 01:31 PM
