Old 01-02-2006, 06:17 AM   #1 (permalink)
PIE amp install
Hey all,
I did some searching and found some good info. I am going to install a pie amp adapter to my sirius starmate replay going through aux to match volumes of radio. I am not real sure how the wiring will go. Although I am not an audiophile by any means I think I can follow a schematic. Does anyone know of a thread where someone has drawn a schematic for this install? Or could someone do me a big favor and draw one if not too hard, I would really appreciate it.
Thanks in advance
Mike
MikeZ is offline   Reply With Quote
Old 01-02-2006, 08:27 AM   #2 (permalink)
uititan's Avatar
Re: PIE amp install
Did you already check these threads? I don't recall seeing a diagram, but the pics may help.
Hardwired MP3 Player
My aux input solution
uititan is offline   Reply With Quote
Old 01-02-2006, 09:12 AM   #3 (permalink)
Re: PIE amp install
Thanks for the links. For whatever reason, I seem to follow diagrams better and was hoping someone had posted one. I think I understand what these guys did but would feel better if I saw it in a diagram.
Thanks again
Mike
Old 01-02-2006, 10:04 AM   #4 (permalink)
Sammy Sandbag's Avatar
Re: PIE amp install
Well, if you'd like I can try to draw something up for you. What exactly do you need? Wire colors and polarity or something else?
-Counsel Yourself
2009 Blizzard Pro-4X
Old 01-02-2006, 11:10 AM   #5 (permalink)
Re: PIE amp install
Wow, thanks Sammy. Yes, I will be using the same PIE you used in your install a while back, just instead of the iriver MP3 I will be using my sat radio. But I mainly need a wiring diagram using the PIE, sat radio and AUX. Did that make sense?
Thanks again
Mike
Old 01-02-2006, 11:24 AM   #6 (permalink)
Re: PIE amp install
Okay, it's not a professional schematic, but let me know if this is what you needed. If there's something missing I can add it easily.
-Counsel Yourself
Old 01-02-2006, 11:28 AM   #7 (permalink)
Re: PIE amp install
I should probably also say that this is the way I wired mine up, but there is a different way if you'd like both your sat radio and the OEM aux boosted. You follow the same basic plan, but you cut the AUX line so that it feeds into the input of PIE, then output as shown. That way anything you plug in to the AUX runs through the PIE. Make sense?
-Counsel Yourself
Old 01-02-2006, 11:43 AM   #8 (permalink)
Re: PIE amp install
Sammy, that makes total sense. Wow, I get it now. I think I can handle this no problem. I really appreciate the time!!!!!!
Old 01-02-2006, 12:14 PM   #9 (permalink)
Re: PIE amp install
I was wondering what is the maximum safe input level for the AUX jack? If nobody has info specific to the Titan, does anybody know about the maximum safe level for the AUX input of HUs generally?
Old 01-02-2006, 03:07 PM   #10 (permalink)
Re: PIE amp install
Sammy/others,
I just went to discountcarstereo and they are out of stock for the P.I.E. Anyone know of another web place with a good reputation?
Thanks
Mike
Old 01-02-2006, 04:04 PM   #11 (permalink)
Re: PIE amp install
I got one that I don't need anymore. It's yours for $10 with shipping included, if you want it and can wait a little while.
-Counsel Yourself
Old 01-02-2006, 04:13 PM   #12 (permalink)
Re: PIE amp install
Sammy,
I will take it! Thanks. I will PM you.
Mike
Old 01-05-2006, 08:51 AM   #13 (permalink)
Re: PIE amp install
so lets see a diagram if you want to feed in an xm rca and also boost the aux mini jack. As I see it that cant be done.
2004 Nissan Titan KC 4x4
BT,OR, Locker, fancy rear view Fosgate package
Purchased - 11/18/05 with 9500 miles
TitanNgtiGuy is offline   Reply With Quote
Old 01-05-2006, 09:18 AM   #14 (permalink)
Re: PIE amp install
I thinks eakes posted that there is a device to use the N-Bus sat connector to provide two AUX inputs.
Old 01-05-2006, 09:55 AM   #15 (permalink)
Re: PIE amp install
That would probably work well, wouldn't solve the volume problem though
PRG kit install in MA av8rt Titan Suspension 0 03-25-2005 09:49 AM
Install Kit rrichard Titan Interior Discussion 1 12-19-2004 10:40 AM
Sub And Amp Install kingthreat_one Titan Interior Discussion 37 12-04-2004 09:44 PM
Amp install beano Titan General Discussion 3 05-02-2004 01:07 PM
