Old 01-29-2006, 02:20 PM   #1 (permalink)
Unhappy Factory Center Channel 5.1 Help Pls.
My center channel is quiet as a mouse when playing a 5.1 dvd. (and all other times too..) Factory HU is the RF w Navi/DVD, added only Alpine 600w w JL subs in a stealth box, bypassing the under seat stock subs. Did I disconnect it or what? Need a wiring diagram or a know where to look reply. Help is always appreciated. Don't recall a center channel output gain pot either. I am sure the DVD player has a center output, and I know I have a center speaker top of the Navi.
Sounds great but without the center, the dialog is really soft compared to the rest of the movies sound effects. PS, I also added video up front on the Navi screen..
Thanks!!!
TickleMeTitan is offline   Reply With Quote
Old 01-29-2006, 02:42 PM   #2 (permalink)
Sammy Sandbag's Avatar
Re: Factory Center Channel 5.1 Help Pls.
IIRC the Titan doesn't have 5.1. That center speaker is just a center speaker, not a seperate channel.
-Counsel Yourself
Old 01-29-2006, 02:53 PM   #3 (permalink)
Nissan DVD Mobile Theater System ... (Dealer) was I really fooled into thinking that the center channel is an actual center channel like in Dolby 5.1?? Holy cow, thats just not right.
I must overcome this one Sammy. What purpose does this center speaker serve (channel)and therefore what is it supposed to do? Just mash the left and right together?? The DVD player is a dolby digital, so where o where is that center signal going? Could you explain a bit more? Thanks
TMT
Old 01-29-2006, 03:01 PM   #4 (permalink)
Unless something has changed from '05 (MP3 playback is all that I know of) then there is only stereo from the DVD player. The RF HU only sends left right front and rear to the OEM amp and it produces the center channel and sub. So according to the schematics, no 5.1.
-Counsel Yourself
Old 01-29-2006, 03:15 PM   #5 (permalink)
Hmmmm. So, since I have NO sound whatsoever from the center speaker under any conditions, what do you think I did by disconnecting the factory sub to power my JL's? Did this eliminate the signal back to the center speaker? Any ideas, or a schematic link perhaps? I then surrender and guess that some center is better than none at all... Lemme know thanks!
TMT DeBary,FL
PS:
04LE
Loaded +
PRG's F&R
Bilsteins
XM
NAv
JL x2 woof woof
Boss312's
Truxedo
Crew
front dvd
and 16 other things
Old 01-29-2006, 03:18 PM   #6 (permalink)
Are you getting any sound at all when listening to other sources (radio/cd/etc?)
The center channel is very quiet to begin with, so it may be operating as intended. Messing with the sub output shouldn't affect it in any way.
-Counsel Yourself
Old 01-29-2006, 03:30 PM   #7 (permalink)
Nope, Nada < Nuthin...
Old 01-29-2006, 03:46 PM   #8 (permalink)
Well then I'd say you have a problem, but how bad do you want it to work is the question. During my install I had all the OE speakers removed except for the center channel. In order to even listen to it I had to crank the volume way up (sorry I don't recall the numerical setting.) My point is, it really isn't doing all that much for you to begin with. But if it's not working at all, then I'd say your dealer would be the one to figure out what's wrong.
-Counsel Yourself
Old 01-29-2006, 04:03 PM   #9 (permalink)
Perhaps you are correct. But when my dealer gets a look inside and sees all the mods, I am afraid they will freak out. I would too if I even let them touch it. Thank goodness I am out of warranty with 41k on the od. Now I can figure out how I am going to make this puppy gimme 5.1. First rip out the current dvd player..... Find them wires.....Next add a dedicated center channel amp............ Hmmmm this is gonna get complikate. I know! No more 5.1 dvd rentals and trrru sterreo soounnnd. L&R the way it should be anyway..hehehe
Thanks Sammy for your input!! Have a great day!
TMT
Old 01-29-2006, 04:23 PM   #10 (permalink)
The 04 wiring for the Rockford system went as follows: (I would expect not any changes for 05 or 06) The four channel output (L and R for front and rear) feed to The Amp. Each speaker group has an output from the amp - L and R for front and rear, center and L and R channels to the subwoofer.
Assuming the new sub-woofer amp is connected to wiring that would normally attach to the Nissan sub-woofer, then there is nothing about that connection which would have rendered the center speaker inoperative.
I would strongly suspect the center speaker is bad. The next potential suspect is the amp channel for that speaker. The simplest test would be to replace the center speaker.
Old 01-29-2006, 05:16 PM   #11 (permalink)
Blue_Water_Rush's Avatar
there are 5 and even 6 channel amps, but usually with the 5s the 5th channel carries more power for use with a sub, and might only send lower frequencies as well, hmmmm..... I wonder if anyone makes a 5 channel amp with equal power per 5 channels. I considered trying to use that center mount for a tweeter when I do my audio overhaul this spring.
A bad day of surf is still better than a good day at work
'05 LE Deep Water Blue/ 4x4/ Off Road/ Big Tow/ Spray In Liner/ Utilitrac
COSMETIC: Undercover Lid/SS Door Accents & Fuel Door/Chrome Tailgate Trim/Dunder Web Grill/Silverstar Headlamps/Volant LED Tail Lights/LED 3rd Brake Light/LED all Int & Ext Lights/ LED Multicolor Interior Accent Lighting/Silblade Wipers/Painted Engine Cover
ENGINE: K&N 77 CAI/Banks Exhaust/AT Grounding Kit/TB Coolant Shutoff/Eco 2 Fuel Vapor Enhancer/Uprev Osiris Tuner & Cipher Software
A/V: Kenwood XXV-01D/JL Audio Amps & 10W7 Sub/MB Quart Spkrs./Sirius Tuner/KK Wiring/SSA Full Sound Deadening/Kuda PDA Base/Laptop GPS with Ram Mount/Tablet DVD with Ram Mount
SUSPENSION: 6" PC Lift/Radflo Coils/3" Deavers/1" Blocks/Bilsteins/PRG Traction Bars/Helo Wheels/PC X Terrain 35x12.50
Blue_Water_Rush is offline   Reply With Quote
Old 01-29-2006, 05:21 PM   #12 (permalink)
grunge311's Avatar
I run my truck 5.1.. I actually just replaced the center channel yesterday...
The RF center is 4ohm, 20rms and 40max. Thats like the best speaker in the whole package.
grunge311 is offline   Reply With Quote
Old 01-30-2006, 03:36 PM   #13 (permalink)
robertc's Avatar
I have the 2006 RF system (no DVD). There is a lot of sound coming from my center speaker. It seems most of the vocals in music comes thru that speaker. It seems to be a midrange speaker.
2006 Nissan Titan SE KC 2WD
Smoke
Born 11-05
Popular Package w/power Captain
Rockford Fosgate 6 Disc MP3/WMA
Utili-trac Channel System
Bedside Lockbox
Rear Sonar System
Step Rails
Creative Zen Sleek MP3 Player (What's an
IPOD )
2007 Nissan Versa SL
Power Package
Convenience Package
Sunroof
5 Disc in dash CD/MP3 /Sirius Satellite
with 8 speakers and Rockford Fosgate Subwoofer
Intelligent Key keyless ignition and entry system
robertc is offline   Reply With Quote
Old 01-30-2006, 04:27 PM   #14 (permalink)
There is a lot of help and insight coming here, thanks all. If anyone has a schematic for the center it would be helpful. I will also check and see if I inadvertently disconnected the center speaker also....if I can remember how to access it. A comment on access would be helpful too. And Eakes, you have 5.1? How is that? Aftermarket? Thanks again.. looking forward to more good stuff...
TMT
Old 01-30-2006, 04:32 PM   #15 (permalink)
I meant Grunge 5.1... Anyway, I cannot recall the connections that were used for the aftermarket JL subs. But if the center is also driven throught the HU amp, then perhaps the connector was totally removed to make way for the Alpine driving the JL subs, whilest that connection was bypassed. The first thing I should check is the connections, if I can remember how to remove the top cover. I am real good at removeing the radio faceplate with a good tug, but the GPS Navi bezel and center speaker top has got me stuck so to speak.
TMT
using 4-channel amp with factory radio, help! BIGT56PA Titan Visual & Audio Discussion 23 01-10-2006 08:56 AM
Replacing center channel speaker grunge311 Titan Visual & Audio Discussion 2 09-28-2005 05:00 PM
Anybody purchased a new center channel/storage tray plastic housing? Justin311 Titan Interior Discussion 13 04-14-2005 08:23 AM
How do you remove the center channel speaker? Justin311 Titan Interior Discussion 2 04-07-2005 12:55 PM
How many channel end stoppers? rcantu Titan General Discussion 12 12-02-2004 08:06 AM
