Re: Switched Power Source Search Back Up Camera Install
Also,I was thinking of splicing into the accessory wire to the ignition switch for the switched +12v since I already added a remote starter and can easily do this now.
40Niner
So where is the ACC wire located on the driver’s side? Any idea how much power it can handle? I know the monitor will not need more than 2 AMPs since that is the fuse rating stated in the manual if that is accurate.
I will look for those plugs on the driver side. They seem like the ticket. I really did not want to run the wires all the way to engine compartment and then through the fire wall.
Did you really find the g/w backup light wire in the driver side kick panel?
40Niner
Yes I did find the g/w wire as it runs to the backup light located above the cab. Pull the driver side kick panel. Notice the wire harness that runs under the factory wire protector. Look where it plugs into the main harness on the drivers side fender well towards the front of the truck, If you dig through it you will see the G/W wire and you could easily pop a wire tap on. If you don’t see it post and I will try to take a pic and post it. (Update) When I tested this G / W wire it was a constant 12v once the truck was on and did not seem to be impacted by the reverse indicator. I ended up running a wire from the back of the truck.
Also where are you thinking of mounting the small monitor. I am thinking to mount it just above and to the left of the rear view mirror. I think I will need to custom make a mount out of metal though. We will see how that turns out. lol!
just wondering but why would u want to get 12volt power from the backup lights inside the cab?? if ur doing a camera install why dont u just get the power from the actual tailight...maybe Im missing something here...
pi3yeargrad
We want to find the power wire to the back up lights inside the cab to avoid a long wire run for no reason. When the wire gets power to turn on the back up lights it will auto turn on the video monitor. Nice option to wire up if you can. Also the switched 12v source and ground are in the same location. Keeping all the wiring local is nice to avoid wire runs for no reason that could cause problems in the future.
2004 Titan SE 4WD,Crew, E-Locker, Big Tow, Off Road, Utility Bed, Bench Seat
