Old 02-01-2006, 07:32 PM   #1 (permalink)
Blue_Water_Rush's Avatar
Question on Power Distribution
I'm upgrading the RF system (actually ripping it out). I have my 250 watt JL Audio sub system which I will be re-incorporating, and a new 4 channel Memphis amp 50 x 4 rms (under-rated). It will be complimented by MClass 6.5 comps up front and coaxials in rear.
The JL class D mono amp calls for a 30 amp fuse (which is what I'm using at the battery presently through an 8 ga. wire) while the new Mem is 40 amp, (2- 20s) so I figured an 80 amp AGU fuse at the battery would suffice, with a 4 ga. wire from battery to distribution block (about 12 to 15 ft.), then 8 ga. to each amp.
My question is: is it necessary to use a fused distribution block, or just a standard power dist. block? (considering the fuse at the battery)
I'm going to be under 500 watts total so I figure I don't need a cap or bigger battery or anything like that.
A bad day of surf is still better than a good day at work
'05 LE Deep Water Blue/ 4x4/ Off Road/ Big Tow/ Spray In Liner/ Utilitrac
COSMETIC: Undercover Lid/SS Door Accents & Fuel Door/Chrome Tailgate Trim/Dunder Web Grill/Silverstar Headlamps/Volant LED Tail Lights/LED 3rd Brake Light/LED all Int & Ext Lights/ LED Multicolor Interior Accent Lighting/Silblade Wipers/Painted Engine Cover
ENGINE: K&N 77 CAI/Banks Exhaust/AT Grounding Kit/TB Coolant Shutoff/Eco 2 Fuel Vapor Enhancer/Uprev Osiris Tuner & Cipher Software
A/V: Kenwood XXV-01D/JL Audio Amps & 10W7 Sub/MB Quart Spkrs./Sirius Tuner/KK Wiring/SSA Full Sound Deadening/Kuda PDA Base/Laptop GPS with Ram Mount/Tablet DVD with Ram Mount
SUSPENSION: 6" PC Lift/Radflo Coils/3" Deavers/1" Blocks/Bilsteins/PRG Traction Bars/Helo Wheels/PC X Terrain 35x12.50
Blue_Water_Rush is offline   Reply With Quote
Old 02-01-2006, 10:09 PM   #2 (permalink)
Re: Question on Power Distribution
The point of a fused block is to protect the smaller gage wire from the block to the amps.
Max recommended fuse for 4 gage is 150 amps.
Max recommended fuse for 8 gage is 100 amps.
Since a short in the 8 gage would blow the 80 amp fuse at the battery before exceeding the max current capacity of the 8 gage, you probably don't need a fused block.
Old 02-01-2006, 10:48 PM   #3 (permalink)
Well put. Thats textbook baby.
Headred15 is offline   Reply With Quote
Old 02-02-2006, 04:46 AM   #4 (permalink)
Thanks, thats good because I just received all my wiring, and the dist. block is built really well, but it's not fused.
weight distribution hitch or not? GO_VOLS! Titan Towing & Hauling 18 01-25-2006 08:34 AM
HDTV distribution over Cat5 f00dstamps Off-Topic Discussion 2 12-21-2005 04:05 PM
Help Selecting Weight Distribution Hitch Justintoxicated Titan Towing & Hauling 20 05-13-2005 04:48 PM
Electronic Brake Force Distribution? jmacougar Titan General Discussion 3 01-31-2005 05:13 PM
Heater, Fan, distribution knobs THyder143 Titan General Discussion 7 09-28-2004 07:44 AM
