Old 02-08-2006, 07:52 PM   #1 (permalink)
Question Audio enhancers sub box???
I just got the box in and it looks like the JL 10 W-3's I want to put in it will be rubbing the carpet! It doesnt look like there is enough clearance. Anybody have any suggestions???
jmcc1980 is offline   Reply With Quote
Old 02-09-2006, 02:49 PM   #2 (permalink)
Internet n00b's Avatar
Re: Audio enhancers sub box???
got any pictures of it?
Internet n00b is offline   Reply With Quote
Old 02-09-2006, 03:11 PM   #3 (permalink)
grunge311's Avatar
Run the sub thru a planer.
Seriously though, how much is the mouting depth of the box, and of the speaker? You could recess the speaker in the box if there is enough room, but then again why buy a prebuilt box if you have to mod it.
The lesson to be learned here is that home depot sells some nice tool kits very cheap. A ryobi circular saw and jig saw is all you need to make a box.
grunge311 is offline   Reply With Quote
Old 02-09-2006, 07:27 PM   #4 (permalink)
Blue_Water_Rush's Avatar
Screw some feet onto the bottom of the box on all the corners. Preferably hard rubber tapered cone type with coarse thread screw in center. Just make sure the seats don't bottom out on top.
A bad day of surf is still better than a good day at work
'05 LE Deep Water Blue/ 4x4/ Off Road/ Big Tow/ Spray In Liner/ Utilitrac
COSMETIC: Undercover Lid/SS Door Accents & Fuel Door/Chrome Tailgate Trim/Dunder Web Grill/Silverstar Headlamps/Volant LED Tail Lights/LED 3rd Brake Light/LED all Int & Ext Lights/ LED Multicolor Interior Accent Lighting/Silblade Wipers/Painted Engine Cover
ENGINE: K&N 77 CAI/Banks Exhaust/AT Grounding Kit/TB Coolant Shutoff/Eco 2 Fuel Vapor Enhancer/Uprev Osiris Tuner & Cipher Software
A/V: Kenwood XXV-01D/JL Audio Amps & 10W7 Sub/MB Quart Spkrs./Sirius Tuner/KK Wiring/SSA Full Sound Deadening/Kuda PDA Base/Laptop GPS with Ram Mount/Tablet DVD with Ram Mount
SUSPENSION: 6" PC Lift/Radflo Coils/3" Deavers/1" Blocks/Bilsteins/PRG Traction Bars/Helo Wheels/PC X Terrain 35x12.50
Blue_Water_Rush is offline   Reply With Quote
Old 02-09-2006, 08:53 PM   #5 (permalink)
The box came with feet but there still doesnt seem to be enough clearance. I have the subs in a couple og wedge typ boxes as a temporary solution but it isnt very comfortable for people if they are in the back. The mountin depth of the box is 5 3/4 which is the same as my subs.
Old 02-10-2006, 04:59 AM   #6 (permalink)
ecbmxer's Avatar
You know, I thought that having the sub pretty close to the carpet was gonna sound bad, but it makes not difference. As long as you have at least a finger's gap around the surround, it will be fine. I was going to space mine up, but I don't think it needs it. Now if you don't even have finger's clearance, I would consider spacing it up a bit.
2005 Titan SE 4x4
Floor Mats
Splash Guards
Nissan Drop-in Bedliner
Front windows tinted to 35%
In-Channel Vent Visors
Front Husky Liners
STEREO:
Pioneer DEH-P8MP Head Unit
ecbmxer
ecbmxer is offline   Reply With Quote
Old 02-12-2006, 05:33 PM   #7 (permalink)
As long as you have enough clearance that would amount to the factory JL grill then it will be fine. That's exactly how the JL stealth box is with the 10w3v2 and it sounds fine.
heath22 is offline   Reply With Quote
Old 02-12-2006, 07:20 PM   #8 (permalink)
rcantu's Avatar
so did you try it out or you just think it will hit? when in a sealed box, subs won't travel the same as out the box. i thought mine facing up was hitting and it's not.
Old 02-13-2006, 06:22 PM   #9 (permalink)
I got some feet to try on it, I will let you guys know how it turns out. Thanks for the input guys!!!
Old 02-19-2006, 10:11 AM   #10 (permalink)
I cut out an area in my rear mats for the woofers...Helped for more clearance...Now the subs fire through the holes in the mats.
Mark Z.
Apopka, FL
04' 4' X 2' SE CC Red Brawn
zracer196 is offline   Reply With Quote
Old 02-19-2006, 11:35 AM   #11 (permalink)
Brilliant!!!
I'll be doing this later!!!
-AD
2005 CC 4x4 SE
AKA
Chunky Ass Whore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is offline   Reply With Quote
Old 02-21-2006, 06:59 AM   #12 (permalink)
ecbmxer's Avatar
I took out the mats and got some smaller universal gray mats. They fit right in front of the box. Although when I rebuild my box I am going to try and make it taller just so I can put the original mats back in.
2005 Titan SE 4x4
Floor Mats
Splash Guards
Front Husky Liners
STEREO:
ecbmxer
Old 02-21-2006, 09:08 AM   #13 (permalink)
ohiodish's Avatar
I took out the mats also and used the front mats side ways in the back so the "titan" logo on the front mats are not sideways or upside down. They also help cover the middle seat floor area in the back. I have rubber mats up front to catch snow, rain water, dirt until winter is over. Sooner the better.
*****God put me on this earth to accomplish a certain number of things....and right now...I'm so far behind I will never die.*****
'04 CC, DVD, NAV, XTANT 4.4 (4 ch. 400 watt) & 6.1 (monoblock 600 watt) amps, JL CS, AudioControl DQS EQ, Two JL Audio 8W7's in a Elegonics enclosure, MB Quart "Q" series 6 1/2" front doors, MB Quart Reference 6 1/2" set rear doors, FATMAT sound deadning, Ipod through JL CS via Scosche IPBCK Bluetooth wirelss transmitter, OPTIMA Yellow Top.
Glassworks Hood
Bushwacker painted flares
NISMO C/A intake (ebay)
Borla dual cat back exhaust (ebay)
Street Scene Chrome Speed Grille & Valance
Pace Edwards Bedlocker (power tonneau)
Procomp lift kit (PRG)
Donahoe Racing front coilovers (PRG)
Bilstein's rear (PRG)
Total Chaos Upper Arms (PRG)
Deaver spring upgrade (PRG)
Weld Racing Velocity 6 XT 18"x10"
Mickey Thompson Baja Radial ATZ 35x13.50x18
Chrome tailgate trim (ebay)
Bermuda Black altezza tail lights (ebay)
PRG Traction Bars
N-Fab Nerf Bars
THANKS GREG!
ohiodish is offline   Reply With Quote
Stock (Titan SE) audio system vs RF audio system... L.O. Little Titan General Discussion 14 12-27-2006 02:27 PM
Diamond Audio Vs. JL Audio whistler Titan Interior Discussion 37 02-27-2006 05:46 PM
Custom Sub Box - Audio Enhancers - EBAY zracer196 Buy/Sell 0 02-04-2006 05:00 PM
Sub Box - For (2) 10" - Audio Enhancers zracer196 Buy/Sell 19 01-23-2006 12:07 PM
JL AUDIO box mikeody2003 Titan General Discussion 4 07-14-2004 05:33 PM
