Old 03-28-2006, 06:27 PM   #1 (permalink)
OEM speaker wire colors
I have an 04 King Cab and purchased a new Sub box with a Kicker Amp. There is no preamp out of course on the factory HU so I want to use the High Input on the amp and wire it directly to the rear door speakers. I am trying to be as minimally invasive as I can so I'm trying not to remove the door panels. I am trying to splice in behind the lower B pillar where the wires pass through to the rear doors. I figure it will be an easy run to behind the rear seat from there. Does anyone know the colors of the speaker wires for the lower speakers in the rear doors of the King Cab for each side? Any help or a better suggestion would be greatly appreciated. If not this then Im soldering in the preamp out as shown on another thread but again as little destruction as possible would be great.
Thanks,
Tim
drosch is offline   Reply With Quote
Old 03-29-2006, 12:33 PM   #2 (permalink)
DryHeat's Avatar
Send a message via AIM to DryHeat
Re: OEM speaker wire colors
05 Titan Factory Stereo Wiring Diagram
................View My Other "Whips"!
DryHeat is offline   Reply With Quote
Old 03-29-2006, 01:55 PM   #3 (permalink)
Sammy Sandbag's Avatar
Even easier, pull up the door sill finisher and you see a plastic wire "tunnel" with wires you're looking for. A lot simpler than pulling off the B-pillar plastic (remove seat belt anchor bolt, both finishers, and the seat.
-Counsel Yourself
Old 03-30-2006, 08:44 PM   #4 (permalink)
Blue_Water_Rush's Avatar
Yeah, there's a lot of wires in there, but you'll know the speaker wires by the fact that they are twisted together in pairs.
A bad day of surf is still better than a good day at work
'05 LE Deep Water Blue/ 4x4/ Off Road/ Big Tow/ Spray In Liner/ Utilitrac
COSMETIC: Undercover Lid/SS Door Accents & Fuel Door/Chrome Tailgate Trim/Dunder Web Grill/Silverstar Headlamps/Volant LED Tail Lights/LED 3rd Brake Light/LED all Int & Ext Lights/ LED Multicolor Interior Accent Lighting/Silblade Wipers/Painted Engine Cover
ENGINE: K&N 77 CAI/Banks Exhaust/AT Grounding Kit/TB Coolant Shutoff/Eco 2 Fuel Vapor Enhancer/Uprev Osiris Tuner & Cipher Software
A/V: Kenwood XXV-01D/JL Audio Amps & 10W7 Sub/MB Quart Spkrs./Sirius Tuner/KK Wiring/SSA Full Sound Deadening/Kuda PDA Base/Laptop GPS with Ram Mount/Tablet DVD with Ram Mount
SUSPENSION: 6" PC Lift/Radflo Coils/3" Deavers/1" Blocks/Bilsteins/PRG Traction Bars/Helo Wheels/PC X Terrain 35x12.50
Blue_Water_Rush is offline   Reply With Quote
speaker wire vilinz1 Titan Visual & Audio Discussion 3 02-16-2006 07:26 PM
What's the difference in wire colors??? tijoseph Titan General Discussion 9 08-04-2005 08:01 PM
Help with wire colors at rear harness HudsonValleyTitan Titan General Discussion 2 01-20-2005 11:23 PM
Speaker Wire Colors ? PoohDaddy Titan Interior Discussion 2 12-15-2004 10:14 AM
stereo wire colors piopremier Titan General Discussion 5 12-15-2004 10:09 AM
