Old 04-27-2006, 07:08 AM   #1 (permalink)
Howmany of you guys out there have installed you own indash dvd player?
so how hard was it and how long did it take you? any problems or issues we might run into? if you did install it your self how hard was it to bypass the parking brake? i still havent deceided which indash to get any suggestions would be awsome!
BulletProof Titan is offline   Reply With Quote
Old 04-27-2006, 07:44 AM   #2 (permalink)
grunge311's Avatar
Re: Howmany of you guys out there have installed you own indash dvd player?
I have done several.. Right now I am using a kenwood, the install for these things is pretty easy, but can be time consuming. In the titan however I thought it was much easier than many vehicles.
I am using a flip out which has a separate brain box that I have under the passenger seat. This is more involved then going with a double din unit which usually is completely self contained.
The parking brake thing is easy, you just ground it. unless you go with a pioneer avic unit, where that doesn't work.
grunge311 is offline   Reply With Quote
Old 04-27-2006, 11:27 AM   #3 (permalink)
Colorado_Titan's Avatar
I installed mine. An Eclipse Double Din. It was pretty easy, and as far as the parking brake goes, the wire is actually labled "Parking Brake", so just ground out that wire. Really easy.
2006 Granite 4x4 LE Kingcab with Offroad package, Big Tow Package, and Power Captains.
Born: 9/05 Mine: 1/06
Colorado_Titan is offline   Reply With Quote
Old 04-27-2006, 01:16 PM   #4 (permalink)
pi3yeargrad's Avatar
I installed my kenwood as well...
Pretty easy...especially if u get the reverse connector for ur stock wiring...u hook everything outside the truck then just snap it into the stock stuff...
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 04-27-2006, 01:47 PM   #5 (permalink)
rave4funn's Avatar
Send a message via AIM to rave4funn
I've got the Clarion flip up in my truck. It is self contained (no external brain). As far as the parking brake wire goes on my unit, you cannot just ground it out. Some newer head units require that the parking brake be released and then applied again. So, my parking brake wire is just a ground but there is a switch on it. Basically, when I go to Visual or DVD mode I have to flip the switch over to break the connection and then flip it back. It is mounted under my dash, very close to my right knee. It was easy to do and I ran my power inverter to it also so that it cuts my X-box off as well.
rave4funn is offline   Reply With Quote
Old 05-01-2006, 06:23 AM   #6 (permalink)
Thanx for your help fellas! Pie3yeargrad were did you get the reverse connector from? also how do you remove the stock face plate? for the indash that have the seperate brain how do you guys run it to under the seat, how do you take off the panels first time doing this! also have you guys install a flip down monitor? Thanx
Old 05-01-2006, 06:39 AM   #7 (permalink)
konigfritz's Avatar
Will most of the Double Din's work or are some to deep for the dash. I remember reading somewhere that a couple people had the units sticking out slightly.
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, JBA Cat back
Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
http://s3.bite-fight.us/c.php?uid=180006
MOΛΩN ΛABÉ
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
12" LCD Monitor DDV player Installed in my CC BlackBart Titan Visual & Audio Discussion 15 07-21-2005 05:34 PM
Aftermarket InDash Cd Changer Receiver hihat123 Titan Interior Discussion 7 12-18-2004 02:19 PM
stock 6 cd indash bikethis Titan Interior Discussion 7 11-24-2004 05:47 PM
Any PICs of indash installs? Jeostang Titan Interior Discussion 3 08-17-2004 12:32 AM
How many guys Had a after Market DVD/Navigation installed? Jeostang Titan General Discussion 10 07-28-2004 07:45 PM
