Old 08-11-2006, 08:31 AM   #1 (permalink)
Satellite radio
Okay don't laugh at me (after reviewing all of your amazing aftermarket installs) but here goes:
My radio reception in the Titan SUCKS..the further away I am from Radio stations the clearer it is...i dunno if my alarm/GPS/ or Remote start that interfers with it or if it just plain sucks....hense my research into Satellite Radio.
Questions...what is a good unit to buy?
Can you still tune into local channels?
Will it improve reception?
What is the general monthly charges?
Also ..is there suppose to be bass in the drivers seat but not passenger? (there is a considerable difference between the two)
I just have the stock 6 CD changer in my LE CC
Thanks in advance!
CdnTitan LE 4x4 is offline   Reply With Quote
Old 08-11-2006, 08:49 AM   #2 (permalink)
Re: Satellite radio
I think most of the popular units are fine. If you go with a Nissan receiver, the advantage is that it interfaces with the N-Bus satellie connection cable (as opposed to the AUX connection) and also works with the steering wheel controls. The aftermarket units are typically less expensive and provide displays with better information.
The satellite receiver provides an additional source, and does not replace existing AM, FM. So you could continue to tune to the same local AM & FM stations you have now, but not using the satellite receiver.
Generally, yes, although you may have cutouts in reception in tunnels, near tall buildins and other obstructions.
Varies depending on the plan you select. They have various special deals they run now and then. Search the net & Sirius & XM web sites for the best deal.
The RF sub is located under the driver's seat. There is no sub under the passenger's seat.
If you have an LE, I think you automatically get the RF system, with the sub under the driver's seat and the external amp up under the driver side dash on the firewall. AFAIK, all of the RF equipped trucks come with the N-Bus satellite receiver interface cable installed and routed under the driver side dash, and are thus read to connect to a Nissan sat receiver.
Old 08-11-2006, 08:53 PM   #3 (permalink)
Re: Satellite radio
K got that ...now what do I do to get the same bass rumble underneath my passenger seat ??
Old 08-12-2006, 07:21 AM   #4 (permalink)
FireCapt103's Avatar
Re: Satellite radio
Let them drive 1/2 the time.
On a serious note, you'd have to add a sub over on the p side.
FireCapt103 is offline   Reply With Quote
Old 08-12-2006, 08:07 AM   #5 (permalink)
Re: Satellite radio
lol k thanks..i'll look into i..i dunno if you noticed..i'm not the most mechanically inclined
Satellite Radio jocast Titan General Discussion 4 05-26-2006 12:40 PM
XM satellite radio LATitan1 Titan Visual & Audio Discussion 4 02-13-2006 07:08 AM
XM Satellite radio NSXER Titan General Discussion 2 02-27-2005 05:16 PM
Who has satellite radio? Hector313 Titan General Discussion 4 09-20-2004 08:00 PM
