Old 08-16-2006, 06:29 AM   #1 (permalink)
need sub wiring help...
i currently have my friends subwoofer in my truck (he is letting me borrow it since he isnt using it) until i get my sub then im givign it back to him but i would like to try to wire both of these subs up to my amp to see what it sounds like but i need help on how i should wire them
here is my buddies sub that im using (omg this thing is heavy)
http://www.onlinecarstereo.com/CarAu...roductID=13321
here is the sub that im buying
http://www.onlinecarstereo.com/CarAu...roductID=14842
now my amp says its 1 ohm stable but i dont really think i want to wire this sort of load to my amp, i mean i think it wold be ok if i did somethign to make shure it stays cool. I would like to know if there is any way that these subs can be wired for 2 ohms, instead of 1 or 4 ohms tho, this is what i have been using as a refrence for subwoofer wiring
http://www.crutchfieldadvisor.com/le...pedance=DVC4x2
04 Nissan Titan LE Crew cab, towing packedge, factory DVD player, Factory Navigation, RF audio packedge, Blaupunkt America SR04 (sirius), flowmaster 50 dual exhaust with electric exhaust cutout, Alpine type X 12", Massive audio 2 farad capacitor, Navone NV-774V, Hifonics BXi 1606D (ran with 2 gauge wire)
mods soon to have:
dual exhaust cuouts
220 amp alternator upgrade
eco_complex is offline   Reply With Quote
Old 08-16-2006, 06:34 AM   #2 (permalink)
TitanEngineer's Avatar
Re: need sub wiring help...
So, If I am reading this right, you do have two subs, correct? If so then wire them to 1 ohm, if your amp says it is stable at 1 ohm, then it should be able to run there without getting hot enough to damage anything. What amplifier are you running? and to answer your question, you can wire one of the subs to 2 ohms but you can not have both wired in mono at 2 ohms.
Under Budget, On Time, To Spec
Choose any Two.
TitanEngineer is offline   Reply With Quote
Old 08-16-2006, 08:57 AM   #3 (permalink)
Wiscdave's Avatar
You will need to wire it 1 or 4 ohm style. You will need to have an amp that is stable that way, which you said you had. Bump it at 1ohm...it should hit nice.
old ride - 04 XE CC 4x4 traded at 62k
Wiscdave is offline   Reply With Quote
PIE LD-1 Wiring tyler2you Titan Visual & Audio Discussion 9 03-11-2007 03:40 PM
wiring help motoman139 Titan Visual & Audio Discussion 4 04-23-2006 10:26 AM
AUX Wiring tulegit Titan Visual & Audio Discussion 3 11-07-2005 10:53 AM
Pls Help...Wiring ??? JIKSER Titan Interior Discussion 4 01-15-2005 03:24 PM
Amp Wiring acontisr Titan Interior Discussion 5 08-25-2004 12:19 PM
