Re: RF 3sixty help
I looked at the specs. It has both high & low inputs. If you use low inputs (at the back of the HU) the only ones available are LF,RF,LR,RR (There is no sub or center out). I believe that the sub & center out signals originate at the OEM RF amp.
The fade control originates at the HU, so I don't think it matters whether you tap at the HU or after the OEM amp.
I think there have been prior posts about the JL Clean Sweep, which seems to be something similar.
