Old 11-17-2006, 09:54 PM   #1 (permalink)
subs help
What are some good subs that'll get pretty loud and shake up the whole truck
but fit under the back seats?
biznutz is offline   Reply With Quote
Old 11-18-2006, 06:43 AM   #2 (permalink)
Supporting Vendor (Gold)
Re: subs help
The mounting depth you're kinda limited on the SPL subs. Subs below I know will fit and are SQL drivers (well some are SPL too)....they will get PLENTY LOUD... as for the "kid bass" as I call it....LOL.....others may chime in and give you some suggestions. You can get subs with a bit more mounting depth in an up-firing box. If you go with a down fire box you are more limited... The most I've seen is 6 inches mounting depth on the down fire box. The up fire box you could go as high as 7 inches.....but I think you would have to remove the grocery hooks under the seat. You could always raise you seats too....I did this on my 2004 Titan and was able to fit taller subs.
Zapco CW-12
Zapco R12H
DLS Nobelium 12's
DLS Iridium 12's
DLS Ultimate
Stereo Integrity 12" MAG D2 (will fit with an up firing box)
Stereo Integrity 12" BM D4 (SPL SUB)
Critical Mass ULS12's
Critical Mass ULS15's
Diamond Audio D612D4
Diamond Audio D612D2
Kicker L7 or L5 in 10" will fit.....those are SPL subs. Not sure if the 12's would fit...probably in an up firing application you could get them too.
"Rainbow, homemade sounds best."
2006 Nissan Titan KC 4X4 SE (Loaded) Galaxy Black
Mods:
Headunit (Kenwood XXV-05V), Amps (Arc Audio XXK-2500's and Sundown Audio SAZ-1500D), Front Stage (Rainbow Platinums, Yes, you read that correct Platinums), Subs (DLS Nobelium 10's) , B-Quiet Utlimate 100sq/ft, Nissan Bug Deflector, Weathertech Wind Deflectors, 35% Tint, DIY CAI Mod
SINNER
Old 11-18-2006, 10:02 AM   #3 (permalink)
tech12volt's Avatar
Re: subs help
i just sold a box to a guy that has a crew cab . he is running memphis m3 subs and these subs are spl subs. they sound o.k. also i have to admit they are one of the better subs for spl and listening. so if you guys have not looked these i would .
tech12volt is online now   Reply With Quote
Old 11-19-2006, 06:49 PM   #4 (permalink)
Taleen The Titan's Avatar
Re: subs help
i have 2 diamond d3 10's under my seat in a custom box with a d6 1000.1 amp. im in high school and all my friends systems are louder than mine, and paid about half the price, as lizard calls it "kidz" bass. my sytem can get loud, but it is mostly for SQ. so, if you want so real bass, you need to drop some $ on install/good equitment. i would recomend 4 jl w7 8" firing horizotal. i herd this in a silverado under the seats, WOW IS ALL I CAN SAY, 2 would probalby do it.
Taleen The Titan is offline   Reply With Quote
JL Subs mnmsmith Titan Visual & Audio Discussion 19 11-13-2006 09:34 AM
need help with subs and amp titanle Titan Visual & Audio Discussion 7 10-13-2006 10:59 PM
Help With Amp And Subs Please!!!!!!! import2nr Titan Visual & Audio Discussion 2 04-22-2006 07:19 AM
DVC Subs 05Titan05 Titan Visual & Audio Discussion 7 08-06-2005 04:38 PM
What sub box - subs are you using for CC Methu969 Titan Visual & Audio Discussion 11 07-11-2005 04:27 PM
