Old 11-30-2006, 12:44 PM   #1 (permalink)
TitanGixx's Avatar
replacing front door speakers ..........
how do i get to them to do so?
i posted this in GD, with just one reply, so i will try my luck in here!
i just need to replace the front 2 in the driver and passenger side doors. I have looked around and dont knoiw if the facing just pops off the bottom of the door or what?
04 SE CC, Smoke
Billet Grille, Toyo Open Countrys, PRG 1" Mini Lift, K&N Filter, 5% tint, MagnaFlow Exahust
04 Suzuki GSX-R 600 Blue/White
tons of Carbon Fiber goodies
TitanGixx is offline   Reply With Quote
Old 11-30-2006, 01:07 PM   #2 (permalink)
CVTITAN's Avatar
Re: replacing front door speakers ..........
No you will need to remove all of the door panel. Becarefull because its in about 3 pieces that are bonded together. Try no to pull on it to hard its better to just pull gentilly around the out side to release the clips. It has screws behind the door release handle and up at the arm rest and handle. Its not hard. I have taken mine off many times. Good luck
- White 06 KC - ProComp Stage 2 lift - Deavers Out Back - K & N Intake - Cherry Bomb Exhaust - 18" Incubus Offroad Chrome Wheels - 35 x 13.5 Toyo A/T'S - Custom Traction Bars (Thanks Aquaholic) - CST Sway Bar End Links - Optima Yellow Top D35 - Jensen VM9022HD - Pyle PLTVATSC1 HDTV Reciever - Farenheit 9" Overhead DVD PLayer Monitor - Sony 4 Channel Amp - MA Audio 6929 & 5029 Speakers - 20% Tinted Windows - Spaw Power Windows And Door Locks Kits - Prodigy Brake Controler - Stillen Brake Booster Support -
CVTITAN is offline   Reply With Quote
Old 11-30-2006, 01:07 PM   #3 (permalink)
the door just pops off, but you have to remove screws in door handle(remove center cover), under arm part(arm part pops off), and 2 bolts under plate where handle to open door at from inside.
tjmutlow is offline   Reply With Quote
Old 11-30-2006, 01:11 PM   #4 (permalink)
Carbeaux's Avatar
As an aside to this, what size are those speakers?
Hook 'Em Horns!
Old 11-30-2006, 01:16 PM   #5 (permalink)
CVTITAN's Avatar
The speakers are 6x9's.
Old 11-30-2006, 02:53 PM   #6 (permalink)
Carbeaux's Avatar
Thanks CV. I'll be doing this to mine at some point, so thought I'd ask.
Hook 'Em Horns!
Old 11-30-2006, 03:43 PM   #7 (permalink)
CVTITAN's Avatar
Glad I could help.. Let us know how things turn out. Remember that the factory speakers are 2 ohm. So if you plan to use the factory stereo the volume level will decrease.
Old 12-01-2006, 12:06 PM   #8 (permalink)
TitanGixx's Avatar
sweet thanks for the info!
now that i know that the front door speakers are 6x9, whats the back door speakers?
i'll post up how it went once i get those kickers in, dont have them yet tho so it might be a cpl weeks
04 SE CC, Smoke
Old 12-31-2006, 11:17 AM   #9 (permalink)
The rear speakers are 6.5".
strippedXE is offline   Reply With Quote
Old 12-31-2006, 11:18 AM   #10 (permalink)
konigfritz's Avatar
arent they component speakers?
konigfritz is offline   Reply With Quote
Old 01-01-2007, 07:05 AM   #11 (permalink)
Originally Posted by konigfritz
aren't they component speakers?
Up front, yes. Replace all of them if you get a chance!!! The stock speakers are of poor quality. Are you putting components up front? If so don't put the after market tweeters in the original stock location, doesn't sound all that great.
Jfree is offline   Reply With Quote
Old 02-04-2007, 10:56 AM   #12 (permalink)
anyone know how to get the tweeters out of the dash?? does that cover just pop off??
And anyone know what size they are?
leukus is offline   Reply With Quote
Old 02-04-2007, 11:02 AM   #13 (permalink)
The little grill cover pops out. The tweet is held by a mounting plate held by four plastic clips that can be easily pulled with a trim panel fork tool (I'm sure people have used other means). To mount new tweets, you can make a new mounting plate with whatever size hole you need for your new tweet, and then drill holes in the corner for the clips. People have used aluminum and also lexan to make the mounting plate.
Old 02-04-2007, 11:09 AM   #14 (permalink)
travelship's Avatar
Infinity and Image Dynamics have 2 ohm drivers.
04 4X4 LE Crew Cab, Purchased Used 3-06, Sold 3-09
Gone, but not forgotten!
Without Trucks, America Stops
If you got it, a truck brought it.
"Don't waste your breath to save your face, When you have done your best,
And even more is asked of you, Fate will decide the rest" --The Grateful Dead
"I've seen too much not to stay in touch with the world made of love and luck,
I've got a big suspicion about ammunition, I never forget to duck" --Jimmy Buffett
travelship is offline   Reply With Quote
Old 02-05-2007, 08:04 PM   #15 (permalink)
Justintoxicated's Avatar
Factory Stereo is like 10-11 watts of power....So even if you go buy 2 ohm comps they are going to suck with power from the Factory HU.
I swear my eclipse HU (13 watts per channel I believe) was much louder!
Replacing Front Door Speakers? TitanGixx Titan General Discussion 5 11-30-2006 03:21 PM
Replacing Door Speakers Help billies714 Titan Visual & Audio Discussion 15 01-30-2006 06:34 PM
Two speakers in front door? grunge311 Titan Visual & Audio Discussion 8 08-03-2005 08:33 AM
Replacing Rear Speakers with 2 ohm 6.5s? kerswell Titan Visual & Audio Discussion 16 06-15-2005 11:44 PM
Door Speakers Installed, Front Bumper Smashed DesertTitan Titan Interior Discussion 2 01-10-2005 01:09 PM
