Will Garmin StreetPilot 7200 fit behind NAV Bezel
Just purchased a 2006 Titan LE CC w/o Navigation. I'm interested in installing a Garmin 7200 but ONLY if I can get it to fit inside the NAV Bezel. Surface mounting a $900, 7" NAV screen would probably be too much of a temptation to thieves for my liking. Plus I want to hide all the cables....
My concern is the depth available behind the bezel.
The Garmin 7200 is two (2) inches deep. Will there be any interference behind the bezel?
I also realize I will have to modify the faceplate of a NAV Bezel to allow access to the ON/OFF switch located below the touch screen, center front of the Garmin 7200. I don't see this as a real problem with a good dremel tool and patience. Hey, I've built and flown three airplanes (this site wouldn't allow me to post the URL to my website, so you can GOOGLE jacklockamy to find my website with current airplane shown], I should be able to install a GPS in my new Titan... IF IT WILL FIT! I would just like to know if anyone knows the allowable depth behind the NAV Bezel before I drop $900 for the Garmin 7200 and $150 for a NAV bezel.
Thanks in advance for any and all advice.
Jack Lockamy
Camarillio, CA
New 2006 Titan LE CC in transit from FL to CA
