Old 12-07-2006, 04:37 AM   #1 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
Speaker baffle template?
I was curious if any of you have a template that you could scan for the speaker adapters. I have someone that will make them for me locally I just didnt want to take the doors apart if someone could scan the template for me.
Thanks!
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 12-08-2006, 02:39 PM   #2 (permalink)
tterrag's Avatar
Re: Speaker baffle template?
I would also really like these as well, please!
06 XE CC 2WD
Granite
tterrag is offline   Reply With Quote
Old 12-08-2006, 03:17 PM   #3 (permalink)
pi3yeargrad's Avatar
why dont u wanna take the door apart...its not hard... then just outline the stock speaker bracket
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 12-08-2006, 03:47 PM   #4 (permalink)
The template depends, in part, on the particular speakers to be installed.
Old 12-08-2006, 05:26 PM   #5 (permalink)
SDGator's Avatar
I just made some for the rears. It's pretty easy actually, I just traced the existing bracket on some 3/4" MDF and cut out with a jigsaw. Tomorrow I'm going to do the fronts.
SDGator is offline   Reply With Quote
Old 12-08-2006, 05:42 PM   #6 (permalink)
t22a80's Avatar
I know its easy, I had them apart before when I deadened the doors. I just didnt want to have to take them apart "again" if someone had it that I could trace onto some MDF and cut them out so I'd be ready and only have to take them apart once more. Its only 17 degrees out.
Chad
Old 12-08-2006, 05:42 PM   #7 (permalink)
t22a80's Avatar
The speakers will be CDT M6i Braxial mount comps.
Chad
Old 12-08-2006, 09:42 PM   #8 (permalink)
bighitter's Avatar
Nice I have a set of M6i's on the way and will be having to redo my baffles as well, going to double up this time to get them closer to the openings in the door panel.
bighitter is offline   Reply With Quote
Old 12-09-2006, 02:05 AM   #9 (permalink)
t22a80's Avatar
I'm really excited for the new speakers... I had the CL's in my tacoma and they were ok. These new line of drivers from CDT are supposed to be awesome.
I will probably double up on the baffles too.
Chad
Old 12-09-2006, 03:07 PM   #10 (permalink)
bighitter's Avatar
I currently have the CF set in my titan and they sound pretty good, but for the cost of the upgrade on just the drivers I cant resist.
Old 12-09-2006, 07:37 PM   #11 (permalink)
t22a80's Avatar
Yah I'm excited to try them. You said you already bought them??
This sounds like a real good deal.
http://www.cdtaudio.com/m6_midbase_driver.htm
I got hooked up and got a better deal though.
Chad
Old 12-14-2006, 03:11 PM   #12 (permalink)
tterrag's Avatar
I'm waiting for JL audio VR 6.5 coax for the back and XR 6.5 comps for the front, links to the dimensions are below.....anybody wanna help a brother out with templates or maybe even baffles themselves, tech12volt?
http://mobile.jlaudio.com/products_c...hp?comp_id=126
http://mobile.jlaudio.com/products_c...hp?comp_id=120
I really need help with this, i don't have tools or time and definitely don't want to f things up!
06 XE CC 2WD
Granite
Old 12-15-2006, 07:56 PM   #13 (permalink)
bighitter's Avatar
I was actually in the middle of ordering them with Don S and got a little side tracked...
Going to put in an order for them tonight.
How much did you end up paying? Did you use the upgrade program?
Mind making a copy of your template and posting it?
Old 12-16-2006, 04:42 AM   #14 (permalink)
t22a80's Avatar
Thats cool, he'll give you the best price available. I did the M6 Braxial setup with the DRT26 silk along with the 500xt upstage module and silk tweets. The package came direct from CDT in California.
I'm painting them today. I'll try to make a copy of it and scan it at work. They didn't come out too great but they should work. I was stupid and removed both door panels to trace the factory plastic bracket onto my MDF before I realized that they are both the same. So if that helps anyone. Just take off one door and trace it 2 times.
Chad
Old 12-16-2006, 04:44 AM   #15 (permalink)
t22a80's Avatar
If you have AIM you can add him to your buddy list under "djdilliodon" he lists all his current specials on there.
Chad
Speaker Help!!!!! RedAlert Titan Visual & Audio Discussion 13 07-12-2006 05:06 AM
speaker grills bbplayajs Titan Visual & Audio Discussion 0 01-11-2006 06:14 PM
speaker suggestions grunge311 Titan Visual & Audio Discussion 22 07-26-2005 05:44 PM
Speaker question? Kalani938 Titan Interior Discussion 28 11-24-2004 02:17 PM
