Old 12-10-2006, 06:15 AM   #1 (permalink)
'07 LE Crew Need DVD!!
Hi All,
I just got my Titan and love it. I do not have the factory dvd but would like to add one. Does anyone know if there are modles that hook up to the factory stero system so the rear controls that are there can still work? And any reccomendations on models would be appricated.
Thanks!
'07 LE Crew 4x4 big tow...
mfginc is offline   Reply With Quote
Old 12-10-2006, 08:31 AM   #2 (permalink)
tholmes's Avatar
Re: '07 LE Crew Need DVD!!
Do a search on Myron Davis. THey make an aftermarket system that integrates seamlessly with your Titan. I think Amazon.com sells them too. Goodluck with the install.
If it's a penny for your thoughts, and you give me your two cents, what happens to the other penny? Taxes, the Democrats tax everything!
Robert Holmes
2005 Titan LE Crew Cab 4x4
Glacier White
Big Tow
RollBack Tonneau Cover
Aftermarket Nav
AVS Bug Shield
6000k HID Conversion
AEM Brute Force Dry Intake
Navone LOC NE-774V (http://www.davidnavone.com/cart.asp?14&pid=155)
Tech12Volt 12in Box
1 12in Boston Acoustics G1 Dual 4ohm Subwoofer
Rockford Fosgate P3001 Mono Amp (300watts rms x 1 at 2ohms, 150watts rms x 1 @ 4ohms)
tholmes is offline   Reply With Quote
Old 12-10-2006, 09:01 AM   #3 (permalink)
baseballfanz's Avatar
You can tap your aftermarket dvd player into the factory harness and have sounds through the speakers, all function of the rear controller would work like factory. The rear controller however is limited to only selecting source (minus the AUX) and volume control. look for llajumpvid's how-to in his sig.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 12-10-2006, 10:35 AM   #4 (permalink)
Okay the Myron Davis seems to be what I'm looking for. Do you know why it has the fm transmitter??? if it hooks up to the factory wiring?? lajumpvid's solution is way over my head !!
Do you know if I can find a local Dealer for the Myron Davis that will do the install?
Old 12-10-2006, 10:39 AM   #5 (permalink)
rvandam's Avatar
Myron Davis just supplies the screen (which is a direct replacement). Nothing else. So you'll still need a player and need to hook it up somehow.
Red Alert 2006 Titan Crew Cab LE 4x2 Big Tow
rvandam is offline   Reply With Quote
Old 12-12-2006, 10:35 PM   #6 (permalink)
The FM modulator just make it easier to get sound through the headunit, the hook up to factory wiring is purely optional but better IMO. It's not hard at all. A good stereo shop should have no problems installing what you want. Like rvandam stated, you need a dvd player or other video input device.
Old 12-14-2006, 08:28 PM   #7 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
if i may let me go a little deeper on fm mods. fm radio plays form like 48 htz to 16k htz. these are not exact numbers but i am close.music and dvds are recorded from 20 hz to 20k. this is the human ears hearing range. so with a fm mod you lose some both on the top and on the bottom. Most people do not realize they are missing it untill they have it switched to a direct input. so if you can go direct it sounds much better.
tech12volt is offline   Reply With Quote
Old 12-18-2006, 07:38 PM   #8 (permalink)
titanpat57's Avatar
man....this is so over my head. I guess I thought the same thing. I have the RF ^cd/changer with the dvd button...I assumed I only needed to plug the screen into the hole(there is a jack) and slide a dvd in in and go...Ill bend over..please don't kick too hard!
2006 4x4 CC Radiant Silver LE - Lazer Lite Cover - Volant CAI and Tails - Keyless Entry (thx BBF) - Big Tow LED Turnsignal Mod - Handmade LED Backup Lights - Remote Start - Front AirDam - Front Tint - Ventshades - SS Sills - SS Tailgate Cover - SS 3rd Brake Cover - Bilstein Struts - Roadmaster Actice Suspension - As many friggin' LED'S I can get my hands on!
titanpat57 is offline   Reply With Quote
Old 12-20-2006, 07:31 AM   #9 (permalink)
We used the AUX input, but moved the connection to behind the dash, so you don't have to plug in the audio, and so you don't see it is plugged in. Much cleaner look.
pharcyde_titan is offline   Reply With Quote
Old 12-20-2006, 01:33 PM   #10 (permalink)
VShortt's Avatar
The Myron and Davis flip down 7" screen and DVD CAN be bought as a package because I have it. However, I would strongly discourage this player. It is a complete piece of crap. I am on my second one in only two years because the first one simply quit working. It was getting power but the functions wouldn't work properly and it wouldn't play the discs. Now my second one (identical to the first) is doing the exact same thing. I will NEVER buy a Myron and Davis DVD player again.
New List of Mods Coming soon
Old 12-20-2006, 01:59 PM   #11 (permalink)
JGs Tighten's Avatar
First off FM modulators suck. There are after market aux wires that wire in to the aux. I have seen them on here and Ebay. I bought 7" screens already in the headrest, dvd player, and wireless headphones in one package from a local audio store for about $1100. No cutting or anything. I think it looks cooler with the two screens anyway. The only thing I don't like is the FM modulator. I will have the aux wire as soon as I have time to put it in. Good Luck on your choice.
[IMG][/IMG]
Bought 3/06----06 Majestic Blue CC LE 2WD, Ram Air Good Hood, AEM Brute Force CIA, Airaid TBS, MG 2/3 Drop, Shorty Antenna, 22" in 305-45-22 Wanli, 2 7" Headrest Monitors, Soundstream DVD, Trendz Vertical Billet added Logo,Smoke LED 3rd brake light and tail lights, Magnaflow 22" with dual tip,Truxedo Lo Pro Bed Cover, McCulloch 8000k H.I.D, Air Dam, Bilstein Shocks, Tint.
Uprev Tuned
Listen to JGs Titan
http://s102.photobucket.com/albums/m...t=100_3460.flv
JGs Tighten is offline   Reply With Quote
WTB- new or used Crew cab LE Smokin Joe Buy/Sell 4 02-20-2007 07:02 PM
Crew cab sub box Yellomantis Titan Visual & Audio Discussion 3 04-15-2006 10:42 PM
04 Titan XE crew cab 46k mi. $17.5K OBO althepa Buy/Sell 0 11-13-2005 04:42 AM
Able to add DVD to SE Crew? adontech Titan General Discussion 4 09-29-2005 10:23 AM
04 LE Crew Cab for sale WOTMTRUCKS.COM Buy/Sell 0 10-01-2004 10:40 AM
