Originally Posted by tech12volt
you probably have a bad adaptor. i have actually seen a lot of these bad lately. i dont really know why. change it and it should clear up.
Just to give an update. Turns out it wasn't the adaptor but I failed to connect the power antenna leads on the harnesses. I didn't think that I needed to since it didn't have what I considered a power antenna. It has the antenna built into the glass and appently there is power somewhere. So now the issue is fixed, thanks tech12volt for the reply.
Now, you need to get your hands on an 06 Pathfinder and glass a box in the cubby holes between the wheels humps and the back door for both sides to hold a 10 (or 8) each.
