So, I did this install and it sounds great except for the title. The static seems to affect all my head unit inputs (Ipod, XM, CD, Bluetooth). This is what I have tried so far:
1. Moved all the wires near the head unit that carrry power away from the RCA's.
2. Tried unplugging the RCA's for the front and back to try and isolate the problem.
3. Turned off the crossovers on the HU, to just use the amplifier.
4. Checked all my power/ground connections.
Pioneer tech support sugguested that I remove the common ground source for all my plug-ins. I have the ipod adapter, HU, and XM adapter all grounded at the same spot. I guess that isn't the greatest idea from what they said.
I'd really just like some ideas of what to check. I suppose I will start unplugging things until it stops.
If you turn down the volume all the way, it goes away. This is not signal noise coming from the alternator. It happens with all the speakers, although I can't really tell if it is happening with the subs.
