Has anyone actually taken thier Titan back to the dealership because the aux made the whining noise? I ask because when I use my Ipod through the aux, at a certain point I can hear that damn noise. I even tried a ground loop isolator, which barely helped, and it still is quite crappy. Should I take it back to the dealer? Its under warranty.
Its an 06. I have tried 2 different cables and the ground loop isolator. The second cable was of better quality and claimed less noise, but you can still hear it.
I have an 04, and I have no problems with my aux in. I do use the Belkin cigarette lighter adaptor, and run the cable from there rather than from the headphone jack on the ipod.
__________________ 04 4X4 LE Crew Cab, Purchased Used 3-06
Rancho Triple X 2" lift, Bilstein rears, Alum Diff Cover, Tint, Benevento Sunroof Deflector, Firestone Air Bags, Primus Brake Controller, 17x8 MB Blitz wheels, LT285/75R17 Nitto TerraGrapplers Audio Upgrade--JL Cleansweep, JL 500/5, ID Chameleons, ID CTXs, Tech box with Sundown SD-1v2, KnuKonceptz
Without Trucks, America Stops
If you got it, a truck brought it.--you think $100 fill-ups in the Titan hurt?? Try $1000 daily fill-ups in a rig!!
"Don't waste your breath to save your face, When you have done your best,
And even more is asked of you, Fate will decide the rest" --The Grateful Dead
"You might tell me where to go, but there ain't nobody gonna tell me what to do" --Van Zant
"I've seen too much not to stay in touch with the world made of love and luck,
I've got a big suspicion about ammunition, I never forget to duck" --Jimmy Buffett
Its not a problem now since I use the JL Cleansweep, it just pissed me off when I had to use the aux. Eq is turned off and all that good stuff. Thx for the replies.
The noise isn't a Nissan problem. The noise is generated from the ipod car charger you are using. Try running just off the ipods battery and use an 1/8" stereo jack cable and you'll see what I mean.
the DC/DC convertors in the ipod car chargers are noisy, some more then others. I have not found one that doesn't make any noise so I plan on building my own.
2005 TITAN LE CC
Radiant Silver
51,000 miles
Thats what I am doing, I dont use the charger and IPOD at the same time.
When you hear the whine, try adjusting your interior light brightness, then click it to the full on position and see if it disappears. I had this problem with an external XM radio and found it to be that rheostat knob and I know someone else on the forum had a similar problem. If you find this to be the problem you can at least have something to show the dealer.
troutspinner
If you're into fishing check out my website! http://www.pennsylvaniaanglers.com
My Aux input worked finethe first 6 months on my 05 and then it started sounding like it was under water or it would only play the center channel of music or just instruments and no voice. I have taken it to the dealership 3 times and they called Nissan Engineers who told them to tell me that what i hear is normal and i shouldnt expect it to work any better. They say it is not designed to run an IPOD or Sat radio or even my sons Portable DVD through the IR headphones in the back. The told me to give them $500 dollars for an Ipod adapter???? Bottom line nissan will not fix or replace the radio because of the AUX port. I will try the headlight dimmer to see if that works but other than that I would appreciate any ideas. I do have the RF radio.
Just WTF do they think the AUX plug is for then? That's unbelievable!
I also get the whine - PLUS - a clicking noise (tick-tock) if the iPOD is plugged in w/o sound.
These noises have occurred using 3 different iPods - 4 diff cables - with and without chargers..
me thinks there IS any issue with the input jack - I'm planning on visiting the dealer soon..
I have the same exact problem on my 06. I know the whine is the cable picking up interference because if I remove the cable the whine goes away, but the ticking remains. I'll be having the dealer address it when I put the truck in for its next service.
My Fast is not concerned with gas mileage...
2006 Crew Cab LE 4x4
(2005 Lemon is gone...)
Smokin Hot Smoke Color
Step Bars
Big Tow
Sirius Satellite Radio
Creative Zen MicroPhoto Player (Screw iPod)
Undercover Tonneau
Nissan All Weather Matts
Update I tried the dash dimmer and the AUX input started working. Now my dealership wants to replace the dimmer. I don't know what good it will do but when it doesn't work I guess I can blame the radio.
