Old 02-04-2007, 03:48 AM   #1 (permalink)
Kenwood DDX 6019 - With Nav - will it fit?
OK, so i am looking to and a DVD Player/ Nav system to the titan. I have a 2006 CC SE - with the factory low end basic CD player. I am trying to find one to fit it and a buddy of mine recommended the 6019. So ob Cructchfield's site it list the headunit will fit bu not the nav system? Why would that be, doesn't the nav system go under the seat or something? Does any know if this will fit?
Thanks
leukus is offline   Reply With Quote
Old 02-04-2007, 09:40 AM   #2 (permalink)
Supporting Vendor (Gold)
P-Dizzle's Avatar
Re: Kenwood DDX 6019 - With Nav - will it fit?
Crutchfields database is not accurate. The KNA-G510 Nav unit mounts remotely. I 100% guarantee this setup will fit.
P-Dizzle is offline   Reply With Quote
Old 02-04-2007, 02:10 PM   #3 (permalink)
bighitter's Avatar
I had this setup in my titan and it fits fine, after I cracked the LCD screen I went ahead and upgraded to the 8017 and was very pleased with the upgrade. I would either suggest getting the 8017 and nav or wait for the 8019. The additional sound shaping is definitely worth it.
bighitter is offline   Reply With Quote
Old 02-04-2007, 02:57 PM   #4 (permalink)
b2sdad's Avatar
i installed mine yesterday...but the oe brackets are not right,the unit sits about a half inch low???? I need an installer trick for this one!
P-Dizzle has been a real help on the bypass tip!!!
b2sdad is offline   Reply With Quote
Old 02-04-2007, 05:23 PM   #5 (permalink)
bighitter's Avatar
What do you mean a half inch low? What trim do you have? I have an SE with the OEM double din opening and it fit fine, though I couldn't use either of the trim peices that came with the units.
Old 02-04-2007, 07:51 PM   #6 (permalink)
b2sdad's Avatar
yeah...just as I said. When I went to snap the face plate back to the dash, the reciever hit the bottom of the faceplate???
I have a 2006 xe cre cab
Old 02-05-2007, 04:23 AM   #7 (permalink)
so is the kenwood better or how about thid model?
Pioneer In-Dash DVD Multimedia AV Navigation Receiver (AVICD2)
Old 02-05-2007, 05:46 AM   #8 (permalink)
hitecredneck's Avatar
will fit but i replaced my defective one with the 8017
hitecredneck is offline   Reply With Quote
Old 02-05-2007, 08:23 AM   #9 (permalink)
Which one do you like better??
Old 02-05-2007, 11:40 AM   #10 (permalink)
the 8017 so far
Old 02-05-2007, 11:46 AM   #11 (permalink)
KMEDLIN's Avatar
Here Are Some Pics Of The One I Put In My Titan.
kenwood-ddx-6019-nav-will-fit-truck6.jpg  kenwood-ddx-6019-nav-will-fit-truck7.jpg
KMEDLIN is offline   Reply With Quote
Old 02-05-2007, 11:47 AM   #12 (permalink)
P-Dizzle's Avatar
Any feedback on the Panasonic.
Old 02-05-2007, 09:49 PM   #13 (permalink)
FreezyTitan's Avatar
I have the same unit with the back up camera. It works great, I bought the XE double din bezel since the aftermarket one from Crutchfield sucks and the color doesn't match 100%.
As for the unit being 1 inch too low, check the positions you use to screw the plates onto the unit. If you used the correct ones, you would only have been able to use three screws per side. You would have 2 screw left over total. It fits great... the only thing else I would like to do is put some spacers or washers behind the screw to push the deck out some to sit flush with the bezel, but all in all, it fits great.
I hope to the get the navigation soon for it....
Titan Sold 12/07:
With the following items included: Kenwood DDX6019 Receiver, G-510 Navigation add-on, Rearview Camera, iPod Control, JBL 6x9 Front & 6.5 Rear Door Speakers, tonneau cover, billet grille w/logo cut-out, & remote start.
Leftovers: 22" Granite Alloy GA3.6 w/General Grabber UHP (305/45VR22), Leveling Shackles, Tech12Volt box with 10" Memphis sub, and a 700W Profile amp.
FreezyTitan is offline   Reply With Quote
Old 02-06-2007, 04:33 AM   #14 (permalink)
where did mount the camera??
Old 02-06-2007, 04:52 PM   #15 (permalink)
b2sdad's Avatar
I used the oe brackets, because they were all metal.... I think I will try the metra one's
Anyone got a Kenwood pi3yeargrad Titan Parts & Accessories 1 11-30-2005 07:14 AM
Kenwood DDX7015 pisswilly Titan Visual & Audio Discussion 13 06-07-2005 08:28 PM
I need help with the Kenwood 7015 bumwreck Titan Interior Discussion 2 05-14-2005 01:26 PM
Kenwood Ddx-7015 scsTiTan Titan Interior Discussion 9 12-12-2004 07:02 AM
