Old 02-16-2007, 03:00 AM   #1 (permalink)
travelship's Avatar
Subs for under front seats.
I'd like to build some boxes for under the front seats, I don't want to lose the space under the rear seat. They would be .35 cf sealed. How much clearance is needed between the magnet and the rear wall of the box? Would a shallow 10 (eD SQ10) be better than a regular 8 (eD 9Kv.2 or Polk Momo)? Any opinions on the eDs or Polks?
04 4X4 LE Crew Cab, Purchased Used 3-06, Sold 3-09
Gone, but not forgotten!
Without Trucks, America Stops
If you got it, a truck brought it.
"Don't waste your breath to save your face, When you have done your best,
And even more is asked of you, Fate will decide the rest" --The Grateful Dead
"I've seen too much not to stay in touch with the world made of love and luck,
I've got a big suspicion about ammunition, I never forget to duck" --Jimmy Buffett
travelship is offline   Reply With Quote
Old 02-16-2007, 07:29 AM   #2 (permalink)
vipzach's Avatar
Re: Subs for under front seats.
I have shaved a little off the wall before to prevent the sub from touching it, but you can have them almost touching. Some subs will have a rubber ring around the magnet, you can take it off to save a little room if needed.
Some of the other guys may have a different opinion, I am just telling you what I have done before.
vipzach is offline   Reply With Quote
Old 02-16-2007, 07:56 AM   #3 (permalink)
TruckinTitan's Avatar
One of the things I have done is figure out the diameter of the magnet and cut a second whole in the bottom of the enclosure and then used fiberglass to seal the circle that was cut... If you are using 3/4 inch MDF you can get a 1/2 inch or more of clearence for your magnet. Thats just what I would do...
Truckin Titan
http://www.cardomain.com/ride/2438993
06 CC White SE
Mods: 22" Neeper N6's ,Nitto Terra Grappler 325/50/22, CST 4" spindle, Radflo 2.0 , Bilstein Shocks, Fabtech 2" block, Airlift Bags ,4 10" Infiniti Reference Series Subs, Glassed box all under the back seat, Boston Acoustics GT 28 amplifier
(1100 watts at 2 Ohms), Flowmaster Tip, Stillen Big Brake Kit, LED license plate lights, 2 degree timing advance. (Thanks Uprev guys!)
TruckinTitan is offline   Reply With Quote
Old 02-16-2007, 09:19 AM   #4 (permalink)
travelship's Avatar
I wonder how much space is needed for airflow from the pole vent, I wouldn't want them to overheat.
Old 02-16-2007, 09:21 AM   #5 (permalink)
travelship's Avatar
I like this idea, I was thinking about making the whole bottom fiberglass.
Old 02-16-2007, 10:57 AM   #6 (permalink)
You could do that but would require more mat than if you just did the diameter of the basket/magnets... Remember Fiber glass is much stronger for curved surfaces... large flat area's require a lot more Mat and resin for structural strength.
Truckin Titan
06 CC White SE
Old 02-16-2007, 11:01 AM   #7 (permalink)
travelship's Avatar
If I do the whole bottom with fiberglass, I would replicate the shape of the stock box, with a tunnel to clear the heater vent so it would not be totally flat. But doing just the hole may be the way to go.
Old 02-16-2007, 12:02 PM   #8 (permalink)
Supporting Vendor (Gold)
P-Dizzle's Avatar
Some subs don't require any space behind the magnet. I recommend JL Audio 8W3V2 D2's. You can pick a pair up for about $250 shipped. These subs are not picky about their enclosure or the power thats running them. They don't require any room behind the magnet and work well in small enclosures. Memphis MC84 is another option. I have not heard the 8" eD's but I would assume the 9Kv would out perform the SQ10 in this application. Just about any 10" sub you use is going to suffocate in 0.35ft^3.
P-Dizzle is offline   Reply With Quote
Old 02-16-2007, 12:17 PM   #9 (permalink)
Interesting... I don't have the fosgate system but you should be able to use the bottom of the box as a mold for the new box,.... just wrap it good in foil and painters tape... That would be a good base for the bottom of the box and then just extend the edges to the length you want your new box to be... Sounds like a good project...
Truckin Titan
06 CC White SE
Old 02-16-2007, 07:43 PM   #10 (permalink)
travelship's Avatar
I had not seen these JLs. A little more expensive than the eDs or Polks, but may be worth it. I think the overall outside height of the box will a max of 5 inches. I plan to use a JL 500/5 that I picked up from CDUBYA. Can they handle the power? Will the 500/5 fit on a rack on the rear wall of an 04 Crew? I am also worried about rattles in the seat hardware and wiring, but I imagine that could be fixed.
Old 02-16-2007, 10:26 PM   #11 (permalink)
P-Dizzle's Avatar
eD's will be about the same price after shipping. They can handle that power easily. You better off having too much power than too little.
Old 02-17-2007, 09:44 AM   #12 (permalink)
P-Dizzle, what amp would you recommend if I just wanted to run 1 JL Audio 8W3V2 D2 under the passenger seat, while putting the amp under the drivers seat?
woodside is offline   Reply With Quote
Old 02-17-2007, 11:36 AM   #13 (permalink)
P-Dizzle's Avatar
If you already have the 500/5 use it, but will not fit under either seat. One 8" sub isn't going to do a whole lot of damage. Are yo sure you don't want an enclosure under the rear seat?
Old 02-17-2007, 11:54 AM   #14 (permalink)
tech12volt's Avatar
let me say if all your wanting to do is add a little bottom end. If you are expecting some boom. Start over. 8s just do not get very loud in sealed enclosures. Its physics again. you really are not moving much air with that cone. as long as you you know what you are getting into 8s work great but. if you are expecting to hear 12s out of 8 its not going to happen . even if you could use an 8w7 8 l7 . unless you port them they are just not going to get very loud.
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
Old 02-17-2007, 12:13 PM   #15 (permalink)
P-Dizzle's Avatar
Or run 8 8W3's in a hatch back. Then they kill.
Replacing the front seats... blkbelt65 Titan Interior Discussion 3 01-16-2006 10:59 AM
10" subs under front seats stanzaboi Titan Visual & Audio Discussion 7 11-11-2005 09:10 AM
subs under front seat hunka27 Titan Interior Discussion 9 02-20-2005 10:46 AM
Front Seats WazzuCoug Titan Interior Discussion 3 12-03-2004 04:40 PM
is there pre-wiring for subs under seats? BIGT56PA Titan Interior Discussion 15 11-25-2004 08:54 AM
