Re: Amp to sub
The next question to ask is, can your amp handle a 2 ohm load continuosly? If the answer is yes, then connect the subs voice coils in parallel, connect the "+" to the "+" and the "-" to the "-" of the two voice coils, then connect them to the conector in the box. If the amp cannot handle a 2 ohm load continuosly, you will need to wire the subs voice coils in series. Connect one "+" to the opposite voice coil "-", and then run your wires from the box connector to the remaining "+" and "-" of each voice coil. Hope this helps, and happy tunes!!
Scott
'06 Titan SE KC, Deep Water Blue, Popular Pkg., Utili-track bed system, OEM hitch, Banks Exhaust, Infinity 10" Subs x2, MTX Thunder 801 amp, Power Acoustic LT960 amp, Pioneer/Sony Door speakers, 6000K HID's, K&N Drop in Filter, Air Box Mod, Helix TBS
