Old 02-20-2007, 01:48 PM   #1 (permalink)
dash kit - 2007 SE
I'm getting the run around on finding a head unit kit for my 2007 SE.
Anyhow, just got off the phone with a local "professional" shop that I've done a lot of business with... they said they have nothing listed for the 2007...and don't have any difference between the XE and SE for prior years of the Titan.
Told them to look up an Armada 2007, they said they have a kit for that but it doesn't look anything like the 2004-2006 kit for the Titan. I'm really confused, because the 06 and 07 SE LOOK the same.
I just need a single DIN unit, but wouldn't mind a double din so I can add a scangauge or soemthing else later. Also the local shop uses "Best" brand kits, which I've not heard of. What make (metra, scosche, best, someone else) should I get, what model and what harness do I need?
Do I need an antenna adaptor too?
Sorry to post this, I've seen all your great write ups on how to do it, but they weren't for a 2007 SE...and after talking to this shop, it sounds like Nissan really changed stuff for the 2007 year.
Thanks!
Jason Kelly
Valley Center, KS
kellyj00 is offline   Reply With Quote
Old 02-20-2007, 07:52 PM   #2 (permalink)
Send a message via AIM to tfritzapexntnet
Re: dash kit - 2007 SE
you def dont need a antenna adapter, but i bought a scosche and it sucked, had extra holes, but the metra is the ticket right there. i would buy a metra if i was in your position.
tfritzapexntnet is offline   Reply With Quote
Old 02-20-2007, 08:48 PM   #3 (permalink)
Leadsled124's Avatar
not sure but josh started a thread on something similar to this about a week ago. u can find a little more info here.. Calling All LE Trim Titan Owners
'06-Uprev/Stillen Longtubes/JBA Kat-bak/S&B/ 4"Ram/PGM/Trutrac...
Leadsled124 is online now   Reply With Quote
Old 02-21-2007, 01:05 PM   #4 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
here is the kit i have for the 06 dual climate controll . they say it works for the 07 look at it and see if your dash is the same.the center part can be removed for double dins and there is a pocket for the bottom in single dins also her is a pic with blanks for the two holes on the side installed in case you do not have those features. i did realize they wrere in the package.
dash-kit-2007-se-titan-dash-kit-001.jpg  dash-kit-2007-se-titan-dash-kit-002.jpg  dash-kit-2007-se-titan-dash-kit-cdt-box-004.jpg
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
Old 02-22-2007, 07:17 PM   #5 (permalink)
Deth Blooms's Avatar
I just installed the Metra dash kit in my 07 SE. They must have changed something from the 06 to the 07 cuz my ac knobs dont fit in the new kit. The 06 must have had a bigger control panel I guess. Only 2 screws line up with it, and they dont have a cover for the thin slit hole above the knobs. Anyone else have this problem?
AKA "Whatswithallthiswhorestuff"? Whore
07 Crew Cab SE 4x4 Dark Grey
MB Quart Spkrs, Brute Force CAI, Poweraid TBS, Banks Monster Exhaust, Viper Alarm & remote start.
Coming Soon: Lift kit (PRG 4" PP), 35" tires, Grill Craft front grill (black), and box from tech12volt (on order w/ a Sundown 1500D amp)
Deth Blooms is offline   Reply With Quote
Old 02-22-2007, 07:41 PM   #6 (permalink)
Here are some pics of the fitting.
Old 02-22-2007, 07:54 PM   #7 (permalink)
Heres another one cause I couldnt put both in the last post
Old 02-22-2007, 08:03 PM   #8 (permalink)
Big Al's Avatar
Attachment 38180
Wow, looks like a big difference!
Big Al is offline   Reply With Quote
Old 02-22-2007, 08:09 PM   #9 (permalink)
tech12volt's Avatar
Attachment 38180
hey thanks for that info. i just emailed tech support at metra . they are really cool guys . ill have an answer in the morning.
Old 02-23-2007, 05:28 AM   #10 (permalink)
you fellas are saving me a bunch of trouble, Thanks!
oh, sorry about your problem deth blooms!
Jason Kelly
Valley Center, KS
Old 02-23-2007, 11:29 AM   #11 (permalink)
Yeah it really sucks. Now I dont know what to do. I have an appt on monday to get my amps installed so I can order a box from tech12, but if I cant get my deck installed, I cant install a box or amps. Im so frustrated. I wonder if any of the other brands of dash kits work with an 07? If so, I might have to go with one of them and then get a carbon fiber or wood dash kit to cover it cause a lot of ppl on here say the other brands look horrible.
Old 02-23-2007, 12:05 PM   #12 (permalink)
just have them install the amps and run the RCA cables to where the stereo WILL GO... you can probably handle plugging them in yourself.
Good luck.
Jason Kelly
Valley Center, KS
Old 02-23-2007, 12:07 PM   #13 (permalink)
CVTITAN's Avatar
There have been threads where members mod the stock piece with fiberglass and paint.
BIG WHITE TRUCK...
CVTITAN is offline   Reply With Quote
Old 02-23-2007, 12:12 PM   #14 (permalink)
shoot, sorry... also have them run the remote wires for your amps to where the head unit WILL GO, or you'll have to run cables for that too.
Jason Kelly
Valley Center, KS
Old 02-23-2007, 12:52 PM   #15 (permalink)
I did car audio for a living a few yrs back, so I can do all of it, but Im just having them run the power and ground and mount the amps to an amp rack just to save me some time and trouble. But if no one makes a kit that works, its useless.
Black and white KATSKIN interior painted dash and carbon fiber dash kit ChadEberly Titan Interior Discussion 21 05-01-2007 07:02 PM
new 2007 gmc goes down chieflikalotapus War Stories 81 02-06-2007 01:25 PM
How well do you know the 2007 Titan? AgTitan06 Titan General Discussion 4 12-25-2006 10:33 PM
2007 Tundra Hp 4x4blktitan Titan General Discussion 0 10-26-2006 11:31 AM
2007 Titan changes? ufcjeff Titan General Discussion 21 11-21-2005 09:45 PM
