I promised P-Dizzle I would post pics of my "professionally installed"(See screwed down to the carpet) new amplifiers. I am not ashamed of this, but I am not happy. This is a perfect example of what some shops call a "custom" amp install. They had an Excusion in the showroom completely filled with Alpine components and a fiberglass custom console that ran front to back with amps, interconnect, and screens installed in it. All fiberglass enclosure with 8 12's. VERY VERY nice, so Im guessin someone from Alpine did the install, because "my" amps were "custom" installed too!! LOL!! When the shop manager dies, they can skip all the ceremony and bury him, because I already preached his funeral when I picked It up!!!....It sounds really good and clean. I have no complaints on sound. Tech12Volts enclosure is so nice, I can't begin to describe it. Be easy....Be easy.....AND NO DIZZ you can't have my cap. You have to get your own.
2005 Titan 2wd Crew Cab Se
6" Fabtech Lift w/deaver pack-Total Chaos upper arms-braided brake lines-Rear Radlo reservoir shocks-Radflo Coilovers front w/ spacer-4" rear blocks-Prg traction bars-18x9 Moto Metal 950 wheels-Toyo M/T 35-12.50's-Street Scene Chrome Grille-Kenwood DDX7017-OZ Audio 180cs Matrix component set-2 Memphis MS 12" subs in custom Tech12Volt enclosure-Coverking seat covers, Amp Research Power steps, Flowmaster cat back...
Recently installed: Arc Audio 2100XXK amplifier on the top end and a Memphis Mclass 1000D amp on the subs-Optima Battery-Complete system rewire-Remote start.
every time i see that black box and lt grey carpet it freaks me out. i remember after a few minutes you wanted to match the box to your seatcovers.LOL
Please check out www.tech12volts.com
I noticed in the third pic that the plastic cover over the Seat bracket isn't clipped down. Not the round disk that covers the bolt, but the plastic that covers the foot of the seat bracket. I did the same thing and could not live with it, had to pull the seat up to get it to clip on correctly. Not trying to knock your set up. The box looks great!!
'06 SE 4x4 Crew
Majestic Blue
O/R, R/F,T/P,U/P
Chrome Oval Nerfs(Tex. Titan style)
6" Pro Comp lift w/ traction bars,
Eagle Alloys Series 058 wheels,315/70/17 BFG AT KO
Billet grilles
Chrome tow mirror caps
Limo tint rear three windows
APS 787 Alarm w/ auto Start
Wet Okole seat covers
Pioneer TS-SW2541D 10's
PG MS 275 Amp. Made in the U.S.A.
MTX Re-Q
I appreciate that guys. Hey Tech about that black box, I might holla at ya about another enclosure. I am thinking seriously about removing the seat covers. I will just hit you up when I figure it out. BigBlue, its funny you should say that. Thats one of the things that I griped about to the shop. Nice truck by the way. I appreciate the props guys. I am getting stuff together to build my own amp racks for under the seat. I really like how Blue Water did his on CT. Very Clean and semi-simple. I think I am gonna try to tackle that. Thanks again guys.
come on down bro. i ahve 2 table saws and just got a shipment of mdf in and resin today. we can whip those out in a day easy.
Look good, I wish I had a sexy xxk too...Maybe when my tax return gets here. Do you have any high pitched sounds coming from that amp? Come peopl over on caraudio.com were complaning about a bad batch of xxk's right when I was finaly going to have enough cash to get one. Where did you buy it from anyways?
I hear you on the amprack. I still have to find the time to mock one up from cardboard so I can drive over to my friends and weld it up. I'm thinking to use small square tubing and an aluminum plate to mount the amp too but I have not fully decided.
I'm hoping to fit the 1000 watt xxk as well as the 100x2 under the drivers seat in my KC.
Wish I got a tax return... Cdub, that looks good. Are those Wet Okole seat covers? Wait till you all see the rack I am building for my XXV crossovers and nav control module.
Does anyone have a pic of an amp rack? the reason I ask is because I don't think I have ever seen one before. I had 2 amps in my old frontier and they were installed the same way just bolted to the floor. I think your set up looks good CDubya. What seat covers do you have?
Tech12 is building me an enclosure, as I type, for two JL 10W6v2's for my 06 CC. (If you see my sig I have JL throughout. I know a lot of you guys dislike JL but most of it was in my 04 Mustang GT so I swapped some and bought some more. I'll probably change it all out in 6 - 8 months.) I'm really excited about the enclosure. His work speaks for itself so I'm sure I'll be satisfied. I will have to lift the back seat an inch or two but it shouldnt be a problem. I will also build an amp rack for my two amps. I was hoping to get them both under my drivers seat because I have a power inverter and a power capacitor under my passenger seat. My thoughts for an amp rack go like this...
I want to try to get both amps side by side. I will mount them on 3/4" piece of plexi that has been lightly sanded and cut into a frame so the bottom of the amps are exposed for air. It will be secured to the floor about an inch off the ground. Then I will take a small string of about 20 LEDs, countersink and seal them into the plexi. This will create a frosted, glowing rack for the amps. I will also take two 4 inch fans and mount to the bottom of the seat to create more air flow. I may also do the same sort of thing on the passenger side for the inverter and capacitor. What do you guys think?
__________________ 2006 Titan CC SE
Smoke w/ Graphite/Titanium
Aftermarket:
OEM Foglights, All-Season Rubber Floormats, CoverMaster Tonneau, BedRug Bedliner, Hidden Hitch Class III, 7% tint all around
Stereo:
Kenwood DNX7100, KNA-iP300V, XMDKEN100
JL 300/4 pushing JL XR650-CXi (coaxials - front doors), JL XR100-CT (seperate tweeters - dash) and JL XR650-CSi (components - rear doors)
JL 500/1 pushing two JL 10W6v2's in a Tech12Volt enclosure ***ALL JL AUDIO STUFF FOR SALE - PM ME IF INTERESTED***
Performance:
Volant CAI and Ram Scoop, Magnaflow Muffler w/ pipe dumped behind rear axle (hidden)
Thanks guys!! JustIntox I have one of my Arc 2100xxk amps on ebay right now. Might get a deal on it!! My seat covers are by Coverking. I like them, but the Okeles fit much better but priced much higher. HEY TECH, how far is the drive from D'ville to there? I really need(want) to come down there. I just don't wanna foul up your weekends. I just know if I come down there....I will have to borrow gas money to get my amp racked and glass enclosured titan home!! LOL!!! But for real, where is it at and how far?!!
amen bro. i would like to sign up for one of those tax returns as well. i hate april 15th with a passion. now i know why my mom use to tell us to never ask daddy for anything in april. lol
from d ville 4 hours . let me know what weekend and we will just plan it. i need to play with one of these trucks anyway.
