Hello all, I am in need of some help before I go to work on my titan. I Have a 05 titan crew cab. I am doing a complete audio overhaul. Current sytem:
Alpine 9875
Focal polyglass frontstage and coaxil for rear
Downfiring 2 10's box
PPI art series AX400 (best sq amp ever made-owned since 1996)
New system components sitting in my closet
Eclipse cd500
CDT M6 braxil with upstage and no rearfil
sundown audio 4.100 and 2.100
Tech12volt single sub box with amp rack.
CDT sq10 red
3 rolls of rammatt bxt and 8 yards of ensolite (3cans of spray)
Here is wher you guys come in.
1. How much bxt do I need to put a single layer on everything(headliner,floor,door in and out,rearwall,pillars and inside plastic of doors)I have heard many theory, but no one who has used it.
2. My amp is currently under the front seat, what length rca to run for amp under rear seat?
3. Any tips on running wire to avoid noise. I have non now, however when I take everything out I want to run the wires properly?
4. Any tips on running the wires through the door boot. I currently am just using factory wire through the door.
5. Any and all tips you have used on your install, Maybe tools, technique, material. I am trying to avoid as many unessary trips to the home depot!!
6. Any problems you had with interior removal?
7. I have spent 4 weeks of nightly research on titan talk for tips, but please add any threads you used that help. I want to learn from your mistakes!!!
