Old 02-23-2007, 08:48 PM   #31 (permalink)
Justintoxicated's Avatar
Re: Need Suggestions: Amps and Wiring and Battery for KC.
Originally Posted by P-Dizzle
P-Dizz, how do these stack against Odyssey/Stinger? I believe Odyssey has 4 year warranty where as this one only has a 1 year... I'm thinking the Odyssey might be wortht he extra $60? Is the 2000 the model I need or could I go with teh 2400?
Old 02-24-2007, 01:15 AM   #32 (permalink)
Supporting Vendor (Gold)
P-Dizzle's Avatar
HC2000 is perfect. Battery warranty's are usually BS. After the first year they are all prorated anyway. I have never had a problem with a Kinetik battery. Most company's will give you a some lame excuse why the battery went bad and not cover it under warranty anyway. My vote Kinetik HC2000 100%.
P-Dizzle is offline   Reply With Quote
Old 02-24-2007, 01:34 AM   #33 (permalink)
P-Dizzle's Avatar
One of my favorite companies for amps is Lanzar's Optidrive line. Yes the rest of their amps are the same as Boss, Legacy, Pyramid, etc. But the Optidrive series is a great amp and I have been running them for years. MSRP on the OPTI1000D is $530 but you should be able to pick one up for about $225.
OPTI1000D
- Phase 0-180 degrees
- 0-18dB bass boos
- Low pass filter 50-250Hz
- Subsonic filter 15-40Hz
- 650 RMS @ 2 Ohms
- 900 RMS @ 1.3 Ohms
- Fuse 30A x 3
- Dimensions 10.08" x 2.12" x 12.59"
- 2 Amps can be bridged
Old 02-24-2007, 01:46 AM   #34 (permalink)
P-Dizzle's Avatar
A good 2 channel amp for your comps with a super small footprint is the OPTI2X300D measuring 6.6" x 1.69" x 11.41". 150 x 2 RMS @ 4 Ohms. MSRP is $375 but you can pick this amp up for $165. These amps aren't a direct match but this is a hell of a setup for under $400.
Old 02-24-2007, 01:53 AM   #35 (permalink)
P-Dizzle's Avatar
I have not tried the PDX series from Alpine but I have never been impressed with any of their amps. I had a few clients request all Alpine systems in the past and I don't care for any of their products besides their head units. I used the MRD-M1005 last year and at the same price it wasn't half the amp my Opti is.
Old 02-24-2007, 02:09 AM   #36 (permalink)
P-Dizzle's Avatar
Whatever you decide I wouldn't spend to much on amps because you will never hear the difference. One quality amp is as good as the next. Just don't buy junk...
Amps I recommend.
- Sundown (from what I have heard)
- Diamond
- Memphis
- Nakamichi
- Arc
- Audison
- Us Amps
- Helix/Brax
Old 02-24-2007, 03:45 AM   #37 (permalink)
Amps I recommend.
- Diamond
- Memphis
- Nakamichi
- Arc
- Audison
- Us Amps
- Helix/Brax
I feel that way as well, to some extent. But I thought eclipse was quality and I'm pretty sure the ARC 100x2 will blow it away. Now I do have my limitations but I think I'd like to step it up a notch for some real quality this time around. The nice thing about those PDX amps is the way they stack and they really are tiny. My friends 1000 watt is WAY smaller than my Hifonics 300x2 @ 2ohm 150x2 @ 4 ohm amp.
but I'm hesitant to buy a class D amp without whatever tech it is using for my front's. I just don't want to have any issues there and I have spent enough money already. I think I'd ratehr have non matching amps than have something that won't fit or is not exactly what I need.
Perhaps I should stick with the hifonics for now and just ditch my eclipse that has some minor issues. The hifnoics gets hot but I have had it for many years without any issues. (like 6-7 years now)
Now I just need some advice on that Alternator wire and how to hookup the Battery terminal! Heres a better pic of what I have going...
Old 02-24-2007, 08:47 AM   #38 (permalink)
i ran my 0g down under the fire wall and then to the frame and up into the passenger side panel .so i did not have to drill any holes at all.
wilstone is offline   Reply With Quote
Old 02-24-2007, 11:05 AM   #39 (permalink)
P-Dizzle's Avatar
What is your question? You need to run a wire from your alternator to your battery. I have not done my Titan yet, but I believe the cable coming straight up to your teminal is the factory alternator wire. Connect the alternator directly to the battery.
Old 02-24-2007, 11:33 AM   #40 (permalink)
P-Dizzle's Avatar
I see Ascendant has teamed up with Scott Atwell. I can only assume their prices will increase despite their claim fro better pricing.
Old 02-24-2007, 01:12 PM   #41 (permalink)
No idea how you did that since I could not find any openings, I had to drill a hole in my firewall.
But I was asking more what P-dizz was answering. The problem is that the stock power side battery terminal has a bazillion wires coming off it and built in fuses. The stock alternator wire goes to the terminal which is connected to the battery.
In order to use 0ga wire to the amps I bought new terminals and made an extention to the factory terminal. But I still don't have 0ga wire running from the alternator to the factory terminal which is kinda important and I would like to finish it up. I believe the stock wire (4ga?) is welded/soldered/crimped to the terminal I did not see a way to re-use the factory terminal AND use 0ga from the alternator. So I'm wondering if it would be better to just ADD a second wire form the alrernator directly tot he battery and what the easiest way to get at the alternator to do this is.
Old 02-24-2007, 01:16 PM   #42 (permalink)
P-Dizzle's Avatar
Use a ring terminal and cable just like you did with your extension to connect to the battery. I have not looked at the alternator yet but I would assume you will need to solder at that end.
Old 02-24-2007, 01:34 PM   #43 (permalink)
As far as batteries, the Odyssey MJT1750 slides right into the stock posiiton. It's only slightly larger than the stock unit. You even get to reuse the stock, pinch clamp to hold it in place.
I've had mine (actually two in a dual battery install) in for over a month now and love it.
Regards,
John
05 LE CC 4X4 - Red Alert w/every factory option
American Racing Chrome Chambers 17X9 Rims
Offroad/Big Tow
Damello Offroad Custom Rock Sliders
Retrax rolling bed cover
Bed Extender
Rancho 4" lift w/ PRG Traction Bars
Fox Coilovers & Total Chaos Upper A Arms & Deaver Leaf Spring Upgrade Pack
1", Billet block in rear w/Bilstiens
Defender Roof Rack w/6 offroad lights
Mile Marker Winch mount brush guard with Warn 9500 Ti winch
Bushwacker fender flares (black)
John Harden is offline   Reply With Quote
Old 02-24-2007, 01:36 PM   #44 (permalink)
P-Dizzle's Avatar
Two batteries with the stock alternator???
Old 02-24-2007, 01:46 PM   #45 (permalink)
P-Dizzle's Avatar
Odyssey 1700MJT
- 1700 Amps
- 68 Amp hours
Kinetik HC2000
- 2250 Amps
- 102 Amp hours
