Old 02-25-2007, 05:38 PM   #1 (permalink)
jsolar86's Avatar
solobaric
so is it possible at all to put 2 12" solobarics under the rear seat? or is it just too big? I am able to get these subs at an awesome price from a friend and am really set on them now..but if it doesnt work then ill forget about it..thanks guys
05 LE
6" pro comp lift
325/60/20 nitto terra grapplers
20x10 kmc xd series diesel wheels
jsolar86 is offline   Reply With Quote
Old 02-25-2007, 05:50 PM   #2 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
Re: solobaric
it can be done but you would need to raise the seat aboy 2 inches. the only kickers that solos that work without raising the seat. is the l5 tens or 8s.
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
Old 02-25-2007, 05:53 PM   #3 (permalink)
jsolar86's Avatar
Re: solobaric
oh okay well ill forget about that then..thanks tho tech...can you suggest an amp and subs and that will fit in the boxes u make? I would like go get as much good quality loud bass as possible?
05 LE
6" pro comp lift
Old 02-25-2007, 09:04 PM   #4 (permalink)
P-Dizzle's Avatar
Re: solobaric
10L7 with glass bottom???
P-Dizzle is offline   Reply With Quote
Old 02-26-2007, 11:32 AM   #5 (permalink)
WhiteBoy's Avatar
Send a message via AIM to WhiteBoy
Re: solobaric
Don't give up. I have to raise my seats for 2 12W6v2's. I'd like to see what your ideas for raising are.
2006 Titan CC SE
Smoke w/ Graphite/Titanium
Aftermarket:
OEM Foglights, All-Season Rubber Floormats, CoverMaster Tonneau, BedRug Bedliner, Hidden Hitch Class III, 7% tint all around
Stereo:
Kenwood DNX7100, KNA-iP300V, XMDKEN100
JL 300/4 pushing JL XR650-CXi (coaxials - front doors), JL XR100-CT (seperate tweeters - dash) and JL XR650-CSi (components - rear doors)
JL 500/1 pushing two JL 10W6v2's in a Tech12Volt enclosure
***ALL JL AUDIO STUFF FOR SALE - PM ME IF INTERESTED***
Performance:
Volant CAI and Ram Scoop, Magnaflow Muffler w/ pipe dumped behind rear axle (hidden)
WhiteBoy is offline   Reply With Quote
Old 02-26-2007, 12:00 PM   #6 (permalink)
P-Dizzle's Avatar
Re: solobaric
whiteboy. You need to update your camera and ipod interface choices.
Old 02-27-2007, 03:45 PM   #7 (permalink)
Re: solobaric
I have 2 10" L7 under my rear seats and i didnt have to raise the seats. Granted it was very hard to Squeeze them in there but i have about a 5/8 of an inch for the throw of the subs. they face up if you are wondering, and this is in a crew cab.
06 CC Titan custom magnaflow cat back, K&N intake, H.I.D headlights, (2) 10" kicker L7's powered by a kicker SX 1250 amp.
2K6Smoked is offline   Reply With Quote
Old 02-27-2007, 04:26 PM   #8 (permalink)
jsolar86's Avatar
Re: solobaric
interesting..how does it sound? any rattling? and what box did you use?
05 LE
6" pro comp lift
Old 02-27-2007, 07:28 PM   #9 (permalink)
Re: solobaric
well it doesn't rattle at all becuase i took the rear seats out and dyno matted the floor from the center consel back and the back wall. then i did the overhead consels too, they rattled bad before i did it. as far as sound, they hit way hard and sound awsome i listen to it with the bass set on 1 "my DVD player goes from -6 to 6" i have a 1250sx amp wired so they are at 1 ohm.
Old 02-27-2007, 08:29 PM   #10 (permalink)
tech12volt's Avatar
Re: solobaric
yeah you can router out the bottom of the box as well
Old 02-27-2007, 11:00 PM   #11 (permalink)
eduardomi's Avatar
Re: solobaric
What do you mean?
What is dyna matted????
and how do you raise your seats?
Danke schön...!!!
Ed.
eduardomi is offline   Reply With Quote
Old 02-27-2007, 11:08 PM   #12 (permalink)
P-Dizzle's Avatar
Re: solobaric
Originally Posted by eduardomi
What do you mean?
Danke schön...!!!
Ed.
You raise your seats by modifiying the brackets the seats mount to.
Dynamat is a sound deadener.
Tech means you can router the inside of the box where the magnet sits to get more mounting depth out of the enclosure.
Old 02-27-2007, 11:11 PM   #13 (permalink)
eduardomi's Avatar
Re: solobaric
Man oh Man, this is the best forum I've ever been, you guys are exceptional...!!!
thanks for all your expertise!!!
thanks!
/ed
Old 02-27-2007, 11:16 PM   #14 (permalink)
P-Dizzle's Avatar
Re: solobaric
Make checks payabe to P-Dizzle and Co. LOL. But for real, anytime bro. Tech is in Georgia and I am in AZ if your ever in the areas' and need an installer.
Old 02-27-2007, 11:49 PM   #15 (permalink)
eduardomi's Avatar
Re: solobaric
Thanks bro in what part of Az? I am in LA.
I may go to your place to get some installations done!!!
Thanks!
Ed.
8" Kicker Solobaric L7 subs in rear door of King Cab grunge311 Titan Visual & Audio Discussion 33 02-22-2007 09:23 PM
Has anyone got a 10" square solobaric to fit in their Titan? Shift_Stunter Titan Visual & Audio Discussion 11 03-13-2006 07:16 AM
Kicker 10 solobaric L7 sbo76 Titan Interior Discussion 0 02-25-2005 04:25 PM
