Old 03-07-2007, 12:33 AM   #1 (permalink)
realtizight's Avatar
what is better for a sub box .. up or down draft
what is better for a sub box for under the back seats a up draft or down draft box
realtizight is offline   Reply With Quote
Old 03-07-2007, 12:40 AM   #2 (permalink)
Big Al's Avatar
Re: what is better for a sub box .. up or down draft
I've been wondering the same damn thang!
Big Al is offline   Reply With Quote
Old 03-07-2007, 03:51 AM   #3 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
its a personal preference thing. upfiring you can egt alot more mounting depth. and more airspace. and to me just sound better than firing the subs into flooring
downfiring sounds nice if its done correctly. the problem is there really is now way to do it correctly unless you raise the seat or do a sub that takes only .50 of airspace.
Also upfiring gets louder. yes . louder. i have proven this with a meter. why. because you can fold the seat up and let the sub breath freely when you want do spl.
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
Old 03-07-2007, 04:29 AM   #4 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
Or if you want the most ouput check out Tech's ported box.
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 03-07-2007, 10:15 AM   #5 (permalink)
P-Dizzle's Avatar
Just buy all 3.
P-Dizzle is offline   Reply With Quote
Old 03-07-2007, 07:58 PM   #6 (permalink)
tech12volt's Avatar
down draft is what i prefer in a paint booth if that helps.
Old 03-09-2007, 04:23 PM   #7 (permalink)
I think if it's *just* rated on sound, up-firing is best...
*however*... These are trucks. And if anyone else is like me, I like to actually use my truck. That means I need to carry groceries, and throw gear in the back, and do all the other things that truck-owners do. As a result, the maintenance and worry-level with a *down* firing box is signifigantly less.
When I do my setup, I will be doing a down-firing box.
Old 03-09-2007, 05:56 PM   #8 (permalink)
t22a80's Avatar
Thats exactly why I had Tech12 build me a DF box! It came out great!
Chad
Democrate Leader seeks Draft! royr Off-Topic Discussion 4 11-20-2006 06:30 AM
NFL Draft 37L1 Off-Topic Discussion 43 04-29-2006 10:45 PM
2005 Nfl Draft... tortuga Off-Topic Discussion 114 05-06-2005 04:09 PM
Draft info, what do ya think. tikigod Off-Topic Discussion 47 06-08-2004 03:29 PM
