Old 03-07-2007, 01:14 PM   #1 (permalink)
grunge311's Avatar
3 way setup, location suggestions
I am thinking of doing a 3way active up front setup, but haven't decided yet. If I do go 3 way what are the suggestions for placement of the drivers? Here are a few different options I can think of.
1. Woofer in the door, midrange in the kickpanel, tweeter in either the dash or A pillar
2.Woofer in the door, midrange in the kickpanel, tweeter in the kickpanel
3.Woofer in the door, midrange and tweeter in the A pillar
4.woofer in the door, midrange factory tweeter location, tweeter in the a pillar
5.woofer in the door, midrange and tweeter in the kick, a 2nd tweet in the stock dash location
For the speakers... I haven't decided yet, I have a focal k2p 3 way set, and a rainbow vanadium 3 way set, and a lotus/dayton/3 way setup that I will audition and choose my favorite.
Thanks
grunge311 is offline   Reply With Quote
Old 03-07-2007, 01:24 PM   #2 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
Re: 3 way setup, location suggestions
Hmm tough call!
If you can make custom kick panels then I'd put the midrange and woofer down low and the tweeter up in the A-pillar.
Also look at CDT and Dynaudio for some nice 3 way setups!!
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
t22a80 is offline   Reply With Quote
Old 03-07-2007, 01:31 PM   #3 (permalink)
Supporting Vendor (Gold)
P-Dizzle's Avatar
6.5" and 4" in the door. Tweet in the A-Pillar.
P-Dizzle is offline   Reply With Quote
Old 03-07-2007, 01:36 PM   #4 (permalink)
grunge311's Avatar
I don't know how I would fit the 4" in the door but I will look into it.
I thought the midrange and tweet need to be as close together as you can get them.
I have an h701 processor to compansate for time alignment between individual drivers.
Old 03-07-2007, 01:47 PM   #5 (permalink)
P-Dizzle's Avatar
What is the frequency range of the woofer/mid? Do you have enough depth to fit the mid in the a-piller? What are you running for x-overs?
Old 03-07-2007, 01:55 PM   #6 (permalink)
grunge311's Avatar
I think I can fit the mid in the A pillar, the mid is 1.5" our pillars have about that for depth. For xovers I have an h701 4 way active xover, DTA, 30 band graphic EQ, 7 band parametric... this unit is awesome. I don't know exactly but I think I would only run the mid down to maybe 400hz and up to 4000.
Old 03-07-2007, 01:56 PM   #7 (permalink)
P-Dizzle's Avatar
If you would like the mid to accent the tweet put both in the A-pillar and the sub in the door.
Old 03-07-2007, 02:00 PM   #8 (permalink)
P-Dizzle's Avatar
You are going to have some serious High's. What are you running for subs?
Old 03-07-2007, 02:00 PM   #9 (permalink)
t22a80's Avatar
I think TX did something like that with a mid in the a-pillar he said it was really difficult to make sound good.
The good thing is that the a-pillar plastic is cheap so if you dont like it you can replace it.
Chad
Old 03-07-2007, 02:02 PM   #10 (permalink)
grunge311's Avatar
I am having a local shop put 2 L7s in the rear doors of my KC.
Old 03-07-2007, 02:12 PM   #11 (permalink)
P-Dizzle's Avatar
3-Way is usually more difficult than it is worth. Install and Align. I prefer 2-Way with a woofer that has a wider frequency range.
Old 03-07-2007, 02:13 PM   #12 (permalink)
P-Dizzle's Avatar
Gonna weld the doors shut? LOL.
Old 03-07-2007, 05:19 PM   #13 (permalink)
t22a80's Avatar
Hey Grunge, go over on the "other" forum and check out Griffeys install. He put rainbow 8's in his KC rear doors. It looked pretty simple, you should give it a shot. I do think that round would be a lot easier than square though....
Chad
Old 03-07-2007, 05:22 PM   #14 (permalink)
t22a80's Avatar
Yep thats what I've heard! I have never messed with them personally because it always seems like such a pain to find good mounting locations for the mids.
Chad
Old 03-07-2007, 07:49 PM   #15 (permalink)
Justintoxicated's Avatar
I'd say go with a 2 way setup.
Or make custom Fiberglass pods and put Woof,Mid,Tweet all close together in the kicks. Maybe you could get away with putting the woof in the door.
Just rememeb whatever yo select may sound alot different in your truck than in the store, esp if the speakers are in boxes and your going to do IB in the doors.
Using an LOC w/ the RF setup? t22a80 Titan Visual & Audio Discussion 65 01-24-2007 07:38 PM
New setup ? TheHammer Titan Suspension
