Old 03-07-2007, 09:34 PM   #1 (permalink)
Multi channel or 2 amps?
Audio gurus. Debating to either get a 5/6 channel amp for Full system or just get one 4 channel and one mono amp? I was looking at the memphis belle amp. Any input appreciated.
shdw03 is offline   Reply With Quote
Old 03-07-2007, 11:14 PM   #2 (permalink)
Justintoxicated's Avatar
Re: Multi channel or 2 amps?
Depends what you want to do really.
single amp is less to mount and makes a cleaner install.
Multiple amps makes your system a little more versatile. For instance I want to change my sub I don't have to buy a differnet 5 channel amp. or I buy a sub that needs so much power I can't find a 5 channel amp and need to keep the existing one and add a second amp anyways. or I change my components and they need a little more power so I need to buy new amps, or bridge 2 of the channels.
If you know the amp works with all your components, and subs, it fits the dimensions you need, and you will not be swapping or upgrading later. Then by all means go for it.
Yes, I hear/read memphis makes good amps.
Old 03-07-2007, 11:41 PM   #3 (permalink)
Supporting Vendor (Gold)
P-Dizzle's Avatar
Key question is what do you plan on running for subs?
P-Dizzle is offline   Reply With Quote
Old 03-08-2007, 12:14 AM   #4 (permalink)
right now I have a rockford fosgate t1 10" from a few years back, running in my 300zx. I think that the mounting depth is too much though, 6.5". Other than that, I was thinking about alumapro's.
Old 03-08-2007, 08:29 AM   #5 (permalink)
P-Dizzle's Avatar
The thing about 5 channel amps is the mono channel is usually not very powerfull. If you only need 300-400 RMS then it will be fine, but seperate amps gives you a lot more options.
Multi-channel amp question SDGator Titan Visual & Audio Discussion 12 11-30-2006 05:18 PM
Multi Function Gauges PhatSami Titan Engine, Transmission & Drivetrain 2 02-15-2006 09:14 AM
Multi-Ground Plugs sparkplugs.com Sparkplugs.com 3 12-28-2005 09:43 PM
DVD Multi Region Code Kiwi Titan Visual & Audio Discussion 0 11-28-2005 05:51 PM
Warn Multi-mount winch... JAH Titan General Discussion 5 12-14-2004 04:39 AM
