Old 03-09-2007, 01:35 PM   #1 (permalink)
jsolar86's Avatar
Infinity Reference 1252w subs in tech12 box?
would this sub perform okay in the tech12 box....the 2 12" cutout sealed box that you sell on ebay ? they are supposed to be in a 1.25 cu. box i think, so would these work? they have 5 and 1/8 mount depth i believe
05 LE
6" pro comp lift
325/60/20 nitto terra grapplers
20x10 kmc xd series diesel wheels
jsolar86 is offline   Reply With Quote
Old 03-09-2007, 02:31 PM   #2 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
Re: Infinity Reference 1252w subs in tech12 box?
James could tell you more but my guess is no. If they require 1.25 each then its probably not going to happen.
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 03-09-2007, 02:41 PM   #3 (permalink)
jsolar86's Avatar
okay well how about the rockford fosgate stage 3s ..found em on ebay ...5.9 depth and works with a .65 cu sealed enclosure. they are 10s
05 LE
6" pro comp lift
Old 03-09-2007, 02:46 PM   #4 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
the infinitys work fine. those box recomendations are a little bit off. i have actually heard the infinity 12s in a crew cab box of mine and they sound great. the mounting depth on the rockford is wrong., its actually a little over 6 inches.
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
Old 03-09-2007, 03:10 PM   #5 (permalink)
jsolar86's Avatar
which Infinity subs are you talking about? the ones that i listed (Infinity reference 1252w) or the Infinity Kappa 122.7w? i just wanna make sure before i order anything. im hoping u say the reference because those are way cheaper than the kappas
05 LE
6" pro comp lift
Old 03-09-2007, 03:29 PM   #6 (permalink)
tech12volt's Avatar
1252s work well i have not heard the others.
Old 03-09-2007, 03:37 PM   #7 (permalink)
jsolar86's Avatar
thank you! i should be ordering a box from you fairly soon also!
05 LE
6" pro comp lift
Old 03-09-2007, 04:14 PM   #8 (permalink)
I have those infinity 12s in a box right now..they sound OK but would benefit from a bit more space. I think 1 cu ft would sound better than .7
-AD
2005 CC 4x4 SE
AKA
Chunky Ass Whore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is offline   Reply With Quote
Old 03-09-2007, 04:52 PM   #9 (permalink)
jsolar86's Avatar
ahh i just ordered them!...im sure they will be good enough for me...i decided i dont want to be blasted out of my truck by bass...so what dont you like about them?
05 LE
6" pro comp lift
Old 03-09-2007, 05:20 PM   #10 (permalink)
tech12volt's Avatar
poly fill and upfiring and you will get 1 cu foot all day long.
Old 03-09-2007, 06:08 PM   #11 (permalink)
jsolar86's Avatar
what does this mean tech? poly fill?
05 LE
6" pro comp lift
Old 03-09-2007, 06:32 PM   #12 (permalink)
i have the same speakers in a kc and they sound good i am happy . they hit hard . tec how much fill do you think needs to be put in the box ?
wilstone is offline   Reply With Quote
Old 03-09-2007, 06:48 PM   #13 (permalink)
tech12volt's Avatar
ABOUT HALF A POUND PER SIDE.
Got my Tech12 Box! racinboy Titan Visual & Audio Discussion 10 03-09-2007 08:30 PM
tech12 makes another debos titan Titan Visual & Audio Discussion 8 12-31-2006 12:44 AM
2 Infinity 10VQ's Subs For Sale Sammy Sandbag Buy/Sell 1 07-27-2005 11:26 AM
Speed Reference Wire For Nav??? 1BadTitan Titan General Discussion 8 01-05-2005 10:42 AM
Oil filter cross reference needed Titanman Titan General Discussion 24 08-10-2004 03:49 AM
