Old 03-28-2007, 12:19 PM   #1 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
Sundown Audio Subwoofer!
Hey guys check out the info on the new Sundown products including the new "Nightshade" subwoofer!
http://www.soundsolutionsaudio.com/f...0&#entry229050
Its a 15" and would never fit in the Titan witout removing a seat but this could be a sign of good things to come!
Chad
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 03-28-2007, 12:56 PM   #2 (permalink)
Justintoxicated's Avatar
Re: Sundown Audio Subwoofer!
interesting, appears to have the same push terminals, basket, magnet, tinsel leads etc. In fact it looks just like my TC 1000 in the pics only bigger of course. TC must be their build house.
Old 03-28-2007, 01:27 PM   #3 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
it looks very similar to the mag2 from si. very similar.
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
Old 03-28-2007, 01:44 PM   #4 (permalink)
t22a80's Avatar
Well that would make sense.... because of the relationship between SI and Sundown.
I'm sure it has a little SI and a little of other brands in it too!
Chad
Old 03-28-2007, 03:19 PM   #5 (permalink)
Looks closer to TC subs than SI IMO. Looks don't always matter though. Does Si have the woven tinsen leads too?
http://www.tcsounds.com/tc1000.htm
It looks a bit beefier than the TC 1000's although I'm not sure what size they have a picture of on their website. Cone Material is definately different. Just looks like TC is building them is all.
Old 03-30-2007, 02:09 PM   #6 (permalink)
The woofer sitting next to the Nightshade has a TC9 motor on it (although even it was not otherwise built by TC), that is as close as the Nightshade is to a TC Sounds driver. It is not built by TC Sounds nor is it made by the same build house as the currently available SI Mag.
This woofer doesn't share anything with the SI Mag, current or next generation. About the only similarity is that both use triple stack motors, but the Nightshade motor is much larger. The Mag is an SQ driver first and foremost, that happens to get loud due to it's long linear x-max and high power handling. The Nigthshade is an SPL driver that happens to sound good enough to listen to... BL of over 30, Qts in the 0.23 area, relatively high Fs, 6 layer spider, and all that SPL goodness.
Hope that clears things up a bit
sundownz is offline   Reply With Quote
Old 03-30-2007, 02:17 PM   #7 (permalink)
t22a80's Avatar
Hey man, welcome to Titan talk.... You have some real fans here!
Also thanks for clarifying about your new subs!
Chad
Old 03-30-2007, 02:17 PM   #8 (permalink)
P-Dizzle's Avatar
Is this Jacob?
P-Dizzle is offline   Reply With Quote
Old 03-30-2007, 02:23 PM   #9 (permalink)
Yep, this is indeed Jacob. I figured I would stop in and see if there has been any feedback yet
- Jacob Fuller
- Owner, Sundown Audio
Old 03-30-2007, 02:30 PM   #10 (permalink)
P-Dizzle's Avatar
With the help from James of Tech12volt everyone is soon to be running Sundown. Including this cat.
Old 03-30-2007, 03:43 PM   #11 (permalink)
Sure does, looks don't always mean anything, although I looks closer to the TC1000 than TC9 in appearance to me, only much larger.
Looks good, is Fi Building them?
Old 03-30-2007, 04:09 PM   #12 (permalink)
t22a80's Avatar
The one and only! I'm glad to see that you are releasing more new products! And good luck in the future! Cant wait to see what you guys come up with!
Chad Gregory.
Chad
Old 03-30-2007, 04:13 PM   #13 (permalink)
P-Dizzle's Avatar
Chad Gregory.
Chad, do you happen to have 3 first names?
Old 03-30-2007, 04:17 PM   #14 (permalink)
Why would that make him prone to be a serial killer? lol
Old 03-30-2007, 04:29 PM   #15 (permalink)
t22a80's Avatar
I put my last name because Jacob and I have emailed a few times a while back.
I plead the 5th!
Chad
