Old 07-12-2007, 09:27 PM   #16 (permalink)
Re: Help! Air Bag light on
During the installation you disconnected a wire critical to the air bag system. This generated a fault code in the system. Even if you reconnect the wire the fault code is still there. You need to use a code reader and clear the fault code.
dajan4045 is offline   Reply With Quote
Old 07-15-2007, 07:32 AM   #17 (permalink)
great999's Avatar
i had this trouble yesterday
this worked for me the installer could not figure how to get light off
took money off my install thinking i had to pay for reset by stealership
guess i made out on this one
hey nissan im not paying for some easy fix anymore i can find it here for free
titantalk thanks for the help
mods
20'' intimadator rims (hyper black)
305x55x20 nitto terra grapplers
dual exhaust flow master cat back
2.5 inch level (front)
3'' westin step bars (black)
fog lights installed by nissan after purchase
tinted windows
great999 is offline   Reply With Quote
Old 07-17-2007, 12:24 AM   #18 (permalink)
TruckerT-Titan's Avatar
haha at last that f*ucking light went away, thanks for the info starwarz man, that thing has been driving me crazy, literally.....
o4' crewcab with 69k miles and still kicken hard, 2* degree timing advance thanks to tazstitan, Avic d3 nav. h/u , factory flipdown, tech12volt enclouser with 2 hifonics as12r subs, magnaflow single out, volant cool air intake, helix throttle body spacer, big tow package. uniden bearcat cb/pa with sont 400w amp running to pa speaker, lol ****s loud
future mods: 80 shots of nos, vis hood, hid projectors, tonou cover, cst spidles, camburg coilovers, tc upper control arms, deaver springs tc shackles racerunner 2.5 smoothies, banks monster exhaust.
TruckerT-Titan is offline   Reply With Quote
Old 08-19-2007, 01:46 PM   #19 (permalink)
alabama_lowlife's Avatar
add another one to the list.....thanks! worked on the first try.
My car club's website. http://www.undefinedcustoms.com
alabama_lowlife is offline   Reply With Quote
Old 08-21-2007, 11:34 AM   #20 (permalink)
dragonhead08's Avatar
Ditto, you take for granted how helpul this place can be until something goes wrong that boggles the mind. 5mins after a search and BINGO! problem fixed, thanks!
KMC ROCKSTARS 18X9 0 OFFSET 5.5" OF BACKSPACING
TIRES NITTO TERRA GRAPPLER 325/60/18
2" LEVELING KIT WITH PINCHWELD MOD.
dragonhead08 is offline   Reply With Quote
Old 09-07-2007, 09:28 AM   #21 (permalink)
MTHead's Avatar
Thumbs up Re: Help! Air Bag light on
Originally Posted by bestatchess
If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
....the dash will prompt you when you need to switch the key via the red key flash....
...thank you for posting this....I can't beleive how wound up the airbag light had me... ...I don't think I've wore a pair of shoes since.....
MTHead is offline   Reply With Quote
Old 10-01-2007, 12:28 AM   #22 (permalink)
Boss Titan's Avatar
Send a message via AIM to Boss Titan
For a second, i thought this method really didn't work. Then i decided to take a peek under the passenger seat, only to find that the idiot that installed my LOC didn't reconnect the airbag harnesses!!!!
Worked on the first try after i clipped the 2 harnesses in.
I'm so glad i dont have to pay $90 tomorrow when i go into the stealership.
Boss Titan is offline   Reply With Quote
Old 10-07-2007, 01:02 PM   #23 (permalink)
This is awsome place!!!!!!!
Thanks for the information to reset the blinking light IT WORKED!!!!!
petaromero is offline   Reply With Quote
Old 10-07-2007, 02:43 PM   #24 (permalink)
Send a message via AIM to MrJonMan
I've been around for awhile, so I dunno why I didn't check for this thread before I paid $99.90 inlcuding tax to the **** dealership around the corner
MrJonMan is offline   Reply With Quote
Old 10-07-2007, 02:53 PM   #25 (permalink)
Boss Titan's Avatar
DOH!
Check out my Titan @
http://www.cardomain.com/ride/2577242
Mods:
Fog Light Mod, Airaid 'Poweraid' TBS, TB Gasket Mod, OEM Air Box Mod, K&N Drop In Filter, MagnaFlow 18" Muffler, UltraStar Pure White Headlights, Re-Built Nissan Utila-Track Tool Box, Tech 12 Volt Dual 10" Sub Enclosure, Audiobahn 800W Mono Sub Amp, LOC, Custom Sub-Killswitch, 2* Timing Advance, Lotek 3 Gauge A-Pillar, Auto Meter Phantom A/F, Vaccum, and Volt Gauges.
Old 10-07-2007, 03:26 PM   #26 (permalink)
2tall's Avatar
Thank god for this thread. I was thinking my wife was going to be driving my Titan till I had this fixed.. Of course she has an Armada, but still... THANKS
06 Majestic Blue BT/CC LE Fully Loaded DVD/NAV/Leather eXTANG Soft Cover Volant SS Exhaust PRG Level Kit AEM Polished CAI Silverstar Ultras
Active tuning Grounding Kit 2* timing advance
2tall is offline   Reply With Quote
Old 10-11-2007, 12:49 PM   #27 (permalink)
HitNWakes's Avatar
On a side note,
That code will still remain in the memory. But yes, its from turning or leaving your ignition on and dissconnecting the airbag light on the front bezel.
HitNWakes is offline   Reply With Quote
Old 10-17-2007, 03:57 AM   #28 (permalink)
Worked like a champ! Thanks bestatchess, and thanks TitanTalk for all this great info.
Keith, Wiesbaden Germany
"If you wait until the last minute to do it, then it will only take a minute."
yibkeith is offline   Reply With Quote
Old 11-10-2007, 06:41 AM   #29 (permalink)
I had the same issue with my 06 but its good now. Does anyone know how to bypass the parkin brake hookup so my movies will play while I drive? I know its not legal.
teecee is offline   Reply With Quote
Old 12-13-2007, 06:44 PM   #30 (permalink)
i own a 2008 xe and installed leather seats , after unplugging the passenger seat harness, the air bag light came on blinking, after reading this post i went and did it, worked perfect, so it can be done on a 2008 too.
thank you
gynecotj is offline   Reply With Quote
Map Light/Room Light Bulb No.? bradld2004 Titan Parts & Accessories 2 03-03-2007 07:24 AM
FS: OEM light stalk w/ fog light controls tterrag Buy/Sell 5 10-25-2006 02:23 PM
B-LSD light above SLIP light Chaad32 Titan Interior Discussion 3 04-24-2006 06:17 PM
Window lock button. Light or no light? biggieb22 Titan Problems & Dealer Service 8 02-22-2006 02:12 PM
WTT auto light/fog lamp stalk for regular light/foglamp stalk yellowv Buy/Sell 5 09-28-2005 02:07 PM
