The housing design is what lets out all of the "unwanted" light. The D2R/D2S buld is not supposed to go in our housing. Those are OEM HID bulbs for Lexus or Mercedes or Acura....etc. So where does that leave me.......keeping my 9006 HID "blinders" in and aimed correctly, unfortunately the high beams are not aimed now since the install. I called and verified this with the distributor.
Looks good maybe I will try those when mine burn up. Those almsot look like halogens. My Ballasts clearly say D2R on them I can post pictures if need be. My bulbs do not look like those ones though.
Has anyone found some HID bulbs that have the proper connects for the foglights? Mine screw in properly, but I had to wedge the spade type of terminal into the factor plugs and I think this is leading to my problems with only one bulb turning on every so often. Then again the ballsts for my Foglights looked older and have a narrower voltage rating as well.
try using some electrical tape to secure your fog spades. thats what is keeping mine at bay currently....or heat shrink would be better.
I have owned a H.I.D. company for almost 2 years now and have figured out that the stock head light gives the best spread of beam for a hid conversion... I have done over 50 titans in AZ and i have played with projectors and a normal head light and i like the normal head light better. Also what i use my truck for (off road) the sotck head light works the best.. I have my low beams, High beams and fogs done on my truck and i couldnt ask for more. I had 4 hella hids on the front of my truck but i like the lighting i have now better then the 4 hellas. If you have any questions feel free to contact me @ (480)234-8092 Anthony... H.I.D. Lighting & Acc. Inc.
Thanks for the help over the phone, I'm waiting for my overpriced ebay hids to show up (today hopefully). I'll give you a ring when I need parts.
Yea thats what I did, unfortunately every so often one still does not turn on the first try (but they always start on the second) perhpas it is because I did not run new wires I dunno. not a huge deal as it's just the foglights anyways.
Oh yea I bought some cheap taiwan Ebay HID's that actualy seem to work better than my JDM's so I can see how they can be hit and miss. Work better meaning less warm up time on my dad's dodge. Then again it could be anything causing that. The best HID's seem come on bright instantly but are very expensive...
Ok, so here is what i have ordered and will be posting results for. I found a rebased D2R/9006 hid bulb set that is supposed to keep the correct aiming points from the factory. I had to buy a set of D2R OEM bulb wiring connectors to fit the D2R. Hopefully i will be able to obtain my old factory aiming points and keep my HID output where it should be!!!!!
I have the newer d4r HID's in my 04, they actually are oem toyota ballasts with rebased bulbs to fit the 9006, I like them alot, they give out a huge amount of light with very little scatter.
[FONT=Comic Sans MS][SIZE=5]This Boy Just Ain't Right[/SIZE][/FONT]
All Mods removed, none worked for me, drives much better stock
I installed the "rebased" 9006 HID bulbs and i have to admit they are alot better than the regular 9006 HID bulbs. They are covered in the spots where all the light was scattered before. I could bring the aim back to stock vs. the other HIDS had to be aimed way down. If anyone is thinking about doing the HID install i HIGHLY recommend these bulbs i speak of.
See all that annoying glare from that picture above???? With the "NEW" rebased 9006 bulbs you dont have all that. The light is directed where it should be, not everywhere and blinding people.
Maybe it was the way that picture was taken but that does look pretty bad in terms of light scatter. I know I get blinded looking directly into my HIDs but when look at it's beam pattern and where it hits on the road, it is not so bad. I also aimed my fogs down but left my lows in the same position.
Did you get the kit from hidexpert?
KMC ROCKSTARS 18X9 0 OFFSET 5.5" OF BACKSPACING
TIRES NITTO TERRA GRAPPLER 325/60/18
2" LEVELING KIT WITH PINCHWELD MOD.
