Old 02-20-2008, 09:16 AM   #1 (permalink)
MikeB's Avatar
Alternator noise from cigarette lighter outlets
When I plug in an MP3 player or my laptop that has a cigarette lighter adaptor and connect it to the aux port on my stereo i get a bad alternator whine. Is there a filter I can install to help this?
2006 CC Titan SE 2WD BT. Injen Powerflow, TB Coolant bypass, JBA Evol Exhaust with Maglaflow 24" muffler, Bully Dog Power Pup, Leveling kit, $22 helper springs.
MikeB is offline   Reply With Quote
Old 02-20-2008, 09:52 AM   #2 (permalink)
roy365's Avatar
Re: Alternator noise from cigarette lighter outlets
You have a bad ground sir.
0-60MPH@5.82 & 1/4 mile@14.25 Passport GT Timer
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 02-20-2008, 10:18 AM   #3 (permalink)
MikeB's Avatar
Where would I have a bad ground??
Old 02-20-2008, 10:28 AM   #4 (permalink)
roy365's Avatar
Thats the million dollar question. All i know....is anytime i ever had that noise it was a bad ground. Maybe try to make the grounds on your plug touch better. You have to look at your power source you are using.....not optimal for audio at all. You could hardwire it in if you planned on keeping it.
Old 02-20-2008, 10:39 AM   #5 (permalink)
MikeB's Avatar
Hmmm. Maybe I can ground the outlets somewhere else and see if that helps.
Old 02-20-2008, 10:45 AM   #6 (permalink)
roy365's Avatar
Maybe....then again someone else MAY chime in and tell you a filter or better way to rig it up. Good luck.
Old 02-29-2008, 08:56 PM   #7 (permalink)
BigDavid's Avatar
I have the same problem with my new stereo head unit.
Mine sounds like spark plug noise.
Anybody have a solution?
2008 Titan XE King Cab in Radiant Silver
BigDavid is offline   Reply With Quote
12V Cigarette Lighter Socket - HELP! B-RAN Titan General Discussion 9 02-11-2008 10:18 AM
12V Cigarette Lighter Socket - HELP B-RAN Titan Interior Discussion 3 01-28-2008 09:03 AM
How do I fix cigarette lighter? speediq99 Titan General Discussion 4 12-31-2007 05:26 PM
Cigarette Lighter Dragon Titan Parts & Accessories 13 02-23-2005 12:25 PM
12volt Outlets JSTARSPILOT Titan General Discussion 3 06-07-2004 01:30 PM
