Old 04-06-2008, 04:42 PM   #1 (permalink)
Speaker Help!!!
Hello guys, I'm new to the site and need some help! I have a crew cab titan with 2 10-inch kicker CVRs and a kicker zx 750.1 pushing them. all the speakers and hu are stock, and the system sounds great, but i think im ready to add some aftermarket speakers. I really want to keep my 6-disc changer so I have made the decision to keep the factory hu and amp the speakers. Right now I'm leaning towards a kicker 350.4 and sticking with kicker on the speakers as well. heres my problem, if decide to do 4 matching components how hard is it to replace that awkward 2 inch tweeter on the dash with a smaller one, what can be done here?? or is it not really worth the trouble, and just to components in the back seat and stick with a 6x9 coaxial in the front?? Im also consider using a crossover between the two amps and seperating the frequencies before they get to the amp. thank you guys for reading, and I look forward to your responses!
xtwolvestnjx is offline   Reply With Quote
Old 04-06-2008, 08:00 PM   #2 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
Re: Speaker Help!!!
Take a look at some of these pics. This will show you what could be involved.
08 Titan Stereo Install... CDT Comps, REQ-5, Boston Subs, Premier Amps (Pics)
Tech12Volt (James) is the in house car audio dealer, he is a site sponsor and can get you what you need. I suggest the REQ signal converter, sundown amps and I use CDT speakers. Kicker is ok, but there are better options out there for the money.
Go here for more info.
www.tech12volts.com
If you spend some time you will see there are hundreds of posts on this very subject.
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 04-06-2008, 10:33 PM   #3 (permalink)
Re: Speaker Help!!!
I think it'll be worth your while to go through the trouble of getting a good set of components up front. It's not too terribly involved.
I'm not much a fan of Kicker either but, considering most of your equipment is already kicker, might as well get what you want.
Defiant is offline   Reply With Quote
Old 04-10-2008, 12:45 PM   #4 (permalink)
slwilson6's Avatar
Re: Speaker Help!!!
I used kicker 6 1/2 components in factory locations and as you can see from p dizzle's pics any semi flexible metal can be used to make the brackets for the tweeters. i used mdf to convert the factory 6x9 opening in front to a 6 1/2 and sprayed it with a flat black paint so it could not be seen thru the grill. i double stacked 5/8 mdf to make the rear speaker mounts in factory locations.
07 TITAN CREW CAB LE 4X4, LEVELING KIT, 18X9 CUSTOM RIMS, BFG RUGGED TRAILS, K & N COLD AIR INTAKE, TOW PACKAGE, WESTIN DRIVING LIGHTS, BULL BAR WITH OFF-ROAD LIGHTS, STEP BARS, AND TOO MUCH AUDIO EQUIP TO LIST.
slwilson6 is offline   Reply With Quote
Old 04-10-2008, 01:58 PM   #5 (permalink)
WhiteNite's Avatar
Re: Speaker Help!!!
Go to Tech12volt, he is a guru. GREAT guy and will bend over backwards to help you.
WhiteNite is offline   Reply With Quote
speaker options? gabriel c. Titan Visual & Audio Discussion 3 11-27-2006 07:38 PM
Speaker adapters. t22a80 Titan Visual & Audio Discussion 6 11-16-2006 07:28 PM
Speaker Help!!!!! RedAlert Titan Visual & Audio Discussion 13 07-12-2006 06:06 AM
speaker wire vilinz1 Titan Visual & Audio Discussion 3 02-16-2006 07:26 PM
center speaker --how do you get to it? smoketitan Titan Visual & Audio Discussion 4 06-02-2005 01:35 AM
