Old 04-19-2008, 08:15 PM   #1 (permalink)
Sub/Enclosure recommendations
I'm new to the Titan community. I recently purchased a 2008.5 LE CC Majestic blue. So far its the most fun to drive vehicle i've ever owned. I have the Rockford system and want to start by adding some subs and an enclosure. Im on ebay looking for an old Orion 250 HCCA amp, mostly for nostalgic reasons since I used to own one. I was wanting some suggestions on subs that would work in a tech enclosure that would handle that kind of power - any help would be appreciated.
pledger389 is offline   Reply With Quote
Old 04-19-2008, 08:17 PM   #2 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
Re: Sub/Enclosure recommendations
man what a killer amp that was. I miss the old orion stuff so badly.
It depnds on what kind of bass you want. that amp produces sveral different power options depending on what ohm you run it at.
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
Old 04-19-2008, 08:21 PM   #3 (permalink)
I want good clean bass - not window shattering, but better than the toy under the seat. also I want to, if possible, have balance and not drown out the factory door units until I can change all that.
Old 04-20-2008, 04:13 AM   #4 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
I think you will fit in well here!
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Travel recommendations... dank78 Off-Topic Discussion 7 12-04-2007 05:40 AM
any recommendations be00214 Titan Parts & Accessories 1 05-31-2007 10:43 AM
Recommendations for In Dash DVD dram56 Titan Interior Discussion 11 03-30-2005 06:02 AM
Recommendations for LCD? Pwrl3ss Titan Interior Discussion 1 12-16-2004 10:20 PM
Tonneau recommendations Phish Titan Parts & Accessories 13 11-28-2004 07:14 PM
