Old 04-23-2008, 12:54 AM   #1 (permalink)
Titan XE Stereo Swap
I have a 2005 Titan XE which has the single CD/AM/FM Stereo. I would like to swap that one with a the Factory 6 CD changer. Does anyone know if this is a simple task or is the wiring and amp different?
Booshay is offline   Reply With Quote
Old 04-23-2008, 07:32 AM   #2 (permalink)
Re: Titan XE Stereo Swap
This is not a simple swap! The bezel is different when moving up from the 'simple' radio. There is a short cable that goes from the bezel to a harness connector. Wires from that connector and other connectors go to a third connector which plugs into the 'upscale' radio.
If you had the 'pigtail' cable from the bezel and the odd connector that goes into the radio and access to the audio wiring schematic, the necessary wiring could be done. However, I would not recommend this project to a less than experienced person. In short - if you want better sound or more features, go aftermarket.
Titan-Xterra swap lifeinthesouth Titan Suspension 20 05-05-2007 09:36 AM
titan stereo johnnyphaze Titan Visual & Audio Discussion 10 07-18-2006 09:56 AM
Titan engine swap rico387 Off-Topic Discussion 6 12-12-2005 07:38 AM
Titan rear end swap titan05 Titan General Discussion 14 08-30-2005 12:10 PM
04 Titan,did Solid Axle Swap,selling Front And Rear Axles Ect Ect solidaxlenissan Buy/Sell 23 03-10-2005 09:30 PM
