Originally Posted by fam4life
What size speaker is in the dash? Is it a 2" tweet?
How difficult is it to remove the h/u cover and door panels....(I've broken my share.)
Can you mount the amps behind the back seat in the CC model?
How's the electrical system in the Titan?
Anyone have a ported box for 10s under their back seats without a lift mod?
Just some of the questions I have been pondering.
Not sure about the tweets - havn't done my yet, but coming soon..
It takes some time the first time, but once you've done it you can have the h/u out in less then 3 minutes with a single flat screwdriver (to pop the bezel) and a 10mm nut runner. Door panels are slightly more involved, but I can have that off in under 5 minutes now too (5 bolts and a bunch of snaps.)
Yes to amps behind seat - other have done it (I have a kc). Beware of the power window stuff though...
With the electrical, the biggest hangup I've read about here is using a common ground for everything to prevent ground loop feedback. Otherwise, you're gonna be running your own amp power wires so it doesn't really matter.
I'll defer to Tech on the box question...
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
