amp problem
Alright so I was driving and all of a sudden my subs shut off. Then i heard alot of sparking. When i went to check it out, i saw that it was sparking like crazy where the ground was bolted down. Also, the amp will turn on, but the light will flash and all the subs will do is flex in and out, it sounds like a heartbeat. When I turn my truck on all the way, it goes alot faster. All the cables are fine, I've checked everything numerous times. I even regrounded the amp to 2 or 3 different spots and it did the same thing. Does anyone have any idea on what could be the problem?
