Go Back   Nissan Titan Forums > Titan Discussion > Titan Visual & Audio Discussion
User Name
Password
amp is hissing all over the place!!! - being discussed at Nissan Titan Forums in the Titan Visual & Audio Discussion section.
Old 05-10-2008, 05:31 PM   #16
t22a80
t22a80's Avatar
Send a message via AIM to t22a80
Re: amp is hissing all over the place!!!
Do you have another amp that you can try and use to see if thats the problem.
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
t22a80 is offline   Reply With Quote
Old 05-11-2008, 10:21 PM   #17
jbbets
thanks salazar, I'm going to try that out. I have all the wiring still hooked up, I'll give it a try this upcoming weekend. been so busy with mothersday and all. This may be the trick.
the only think is, i know we never had the amp bolted down when we discovered the noise. it was basically hooked up to one speaker just to see if we were getting sound at all before proceeding with the rest, so I'm not sure if the amp was touching any wiring, but I'll definately give this a shot
jbbets is offline   Reply With Quote
Old 05-12-2008, 11:18 AM   #18
eakes
Alternator whine is a nasty animal. It can be picked up due to a ground loop on the DC for HU and amp, radiated into the audio cable between HU and amp or get into the amp because of improper DC filtering in the amp or HU.
Probably the most common is ground loop. To help solve this both HU and amp need to be connected to a good ground. The Titan dash wiring connects the HU to ground which turns out to be at a different potential than the amp, therefore the first step is to insure a good ground at both HU and amp. The amp should be grounded to the chassis in an area where any paint or corrosion has been removed from the chassis metal. Likewise the HU needs a dedicated wire from its case to truck chassis, again the chassis attachment area needs to be free of paint. You can also try connecting the HU case to the ground terminal on the amp. Use at least a #12 wire for this connection. The amp ground wire needs to be the same guage as the wire used to feed its power.
The audio lines between HU and amp need to be good quality and separated from any DC power cables by at least 12 inches, preferably run the amp DC and the audio lines down different sides of the cabin.
Set the audio gain on the amp as low as possible.
If you are using an LOC and are connecting its ground connection, it should be connected to the HU case ground wire.
User Name
Password
Hissing noise coming from the A/C vent? krc333 Titan General Discussion 10 08-14-2007 11:30 AM
1st system ever.... hissing noise??? help!! REYTOS Titan Visual & Audio Discussion 6 11-21-2006 04:45 PM
MP3 player hissing via AUX geemark10 Titan Visual & Audio Discussion 10 11-07-2006 07:13 PM
Hissing Sound When Accelorate CAL-CHRIS Titan General Discussion 15 02-16-2005 07:39 AM
Intermittent Heater Hissing bouak Titan General Discussion 3 12-06-2004 08:04 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
